AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › How to back up movies you've bought from Fios
post #1 of 9
What happens to movies you've bought from Fios if/when you change content providers? Do you forfit what you've bought and paid for if you cancel the subscription? Is there a way to back up my Motorola STB's HDD?
post #2 of 9
Good question, I have always wondered that myself. Can't wait to hear the answer.
post #3 of 9
I don't know Fios in particular. But, in general, these boxes are designed to work only when there is a head-end connection. Once you lose that the contents are unwatchable. That is how it is with Telus(cisco) and Shaw(motorola+Pace) boxes.
post #4 of 9
If the box has analog video out, you can use a Hauppauge HDPVR to record the video to your computer while you play it.
post #5 of 9
My Motorola HD-DVR has a firewire port. My PC is equiped with firewire. I was half arsed hoping this was the solution. However, I have not been able to find anything of use for the Motorola port.
post #6 of 9
That wont work as all "digital" content is protected. That is why the Hauppauge HDPVR needs to use your component outputs as it uses the analog outs to get around the protection
post #7 of 9
I doubt this will work but it might be of some interest. There is a utility called CAPDVHS that is designed to work with some motorola dvrs using the firewire port. At one time I used to record almost any channel in nice HD
to my computer. It was a little flakey but it worked and I still have a pile of movies and shows I captured. The funny thing is the cable tech who installed my box told me about the program and downloaded it for me from the
cable company site. It wasn't available for general downloading but is still out there http://replayguide.sourceforge.net/dct6412/. Unfortunately it requires Win XP, I've never been able to use it on Win 7. The number of
channels it will record has steadily declined hence my doubt it will work for you. Still it's fun to play with and there are channels that can be captured. When you're in the capture window you will see a something, a frame
size if I remember correctly, that indicates a usable file is being captured. It will be in a TS container. I remember one weird capture where I got all the digital channels, say 5.1 5.2. 5.3 etc., at one time and I had to fiddle
around pulling out what I wanted. My motorola dvr had 2 firewire ports and only one of them was active. If you know how to access the service page on yours you can see what ports are active and sometimes what channels
are copy protected. Movies are generally protected.
post #8 of 9
OP's question was not about recording but using the recorded program after he leaves the service provider. The box will not work to play it on either analog or digital outputs.
post #9 of 9
If you record them, then you can play them anytime, even when you leave your provider. It has worked on the 3 systems that I have tried it on just fine.
