AVS › AVS Forum › HDTV › HDTV Technical › What should my cable box resolution out be set to
post #1 of 3
Hello, I have a Motorola (comcast) box and in its menu you can select the resolution the box outputs.
At first I thought it should be set at native, but this causes about a 5 second delay when changing channels, during which the screen goes black (in either 720 or 1080i the current channels remains on for those 5 seconds and then switches). What should I set the output to-720p or 1080i or native? I believe it was originally set by the cable tech at )720p.
post #2 of 3
Either 720p or 1080i. Try each one and use what looks best on your TV.
If your TV has a native resolution of 720p, that may be why the cable set it that way.
In order to avoid a delay when changing channels, do not use native.
post #3 of 3
I would set it to whatever is closest to my display. - ie. - if you have a 720p class display - use that - or if you have a 1080i class display - use that. But in all honesty - it's not really going to matter that much. either the display or your cable box will adapt.
  Back to Forum: HDTV Technical
