AVS › AVS Forum › HDTV › HDTV Technical › Best antenna suggestion? Houston, TX
post #1 of 4
Hoping I can buy a mohu leaf or something equiv, seeing as mounting something isn't really possible in my building.
Thanks in advance AVS!
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d46ae7fe94c18c7
post #2 of 4
Try a simple non-amplified loo and rabbit ears place in front of a south-west facing window.
No need to give the uber-hypsters at Mohu any sales for a mediocre UHF antenna.
post #3 of 4
Title edited to add location as required in antenna help threads.
post #4 of 4
Anyway, yeah, the first thing I'd try is a simple loop and rabbit ears combination that you can get for maybe $15 from Radio Shack or Best Buy. If you don't have a SW-facing window, try it in various locations and orientations in your apartment. TV signals can bounce around in odd ways indoors.
  Back to Forum: HDTV Technical
