CAT5e Vs HDMI
post #1 of 6
Hello Folks --
For my new home, I am opting to run video over CAT5E cables as opposed to HDMI in a multi-room setup. Wondering, if its a good idea to begin with ? Do you guys see any future limitations, issues or concerns with this approach ?
Any feedback would be much appreciated !!!
Cheers
Mayur
post #2 of 6
I don't think there are any TV's or AVR that do video/audio via ethernet cable nor any TV's for that matter. However, I might be wrong and that could be very expensive.
post #3 of 6
post #4 of 6
I would run cat 6 instead. For long runs cat 6 and HDMI baluns will be your best bet.
Sent from my Galaxy Nexus using Tapatalk 4
post #5 of 6
Originally Posted by mpek View Post
Hello Folks --
Cheers
Mayur
You'll be fine and probably the best way to run your A/V solutions through walls and long distances. Just make sure to run CAT6 vs CAT5E just in case to avoid any transmission issue and to future proof. I use HDMI baluns in my bedroom and theater via CAT6 and all work flawlessly including 3D. I've also setup a trio of HDMI baluns behind my best friend's flat panel TV also via CAT6 but the cable runs were just over 100' each and again everything performed flawlessly.
Here's the HDMI baluns I used...
LINK: http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10425&cs_id=1042501&p_id=8008&seq=1&format=2
post #6 of 6
Appreciate all the responses and suggestions well noted !!!
Cheers to you all ...
