AVS › AVS Forum › Video Components › Home Theater Computers › panasonic pt-50lc13 wont stay on
post #1 of 2
I replaced the lamp in my panasonic pt-50lc13 picture works fine for two minutes at a time and shuts down. Why? HELP
post #2 of 2
Definitely wrong forum, but is the fan working? Bottom right side of tv (if facing from the back) is where the fan is. If you don't hear the fan run as soon as you power on, even before you get a picture which takes about 20 seconds then the tv is shutting to save the bulb from over heating.
