AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Need help with setting up 3D properly
post #1 of 9
I just got my 120" Elite fixed frame screen mounted today to go along with the Benq w1070 that I ceiling mounted a few days ago. Lovvvvvve the screen and the projector is pretty nice too.
I've never watched a movie in 3D so I'm not exactly sure what the image should look like. I have a pair of the 144 hz glasses that work with the projector. The problem is when I play the movie in 3D Full HD, the image looks.....
Well I can only describe it as if I were crossing my eyes and looking at the screen. I can't really read any of the print on the menus either. I'm not sure what I'm doing wrong.
Thanks in advance.
post #2 of 9
Really, guys?
All these posts here about 3D being great on this projector and that projector and no one can give me any advice?
post #3 of 9
Sounds like your sync polarity is reversed for your glasses. Check your projector's 3D menu for a "reverse sync" or similar control.
td
post #4 of 9
Will do. Thanks
post #5 of 9
What Glasses did you get? Watched star trek last night and was blown away at the quality
Blake
post #6 of 9
post #7 of 9
Blake
So you didn't have to switch anything up on the projector?
post #8 of 9
No i have a PS3 hooked up thru a dennon 2113 to the benQ 1070 and all i do is pop in the 3d movie and it detects it automatically.
I started with the Sainsonic 144hz and then switched to the monoprice 144hz versions, much better with the red flash and to me the contrast ratio .
Blake
post #9 of 9
Blake
Thanks. I believe I got mine working but the flashes are a pain to deal with. I wear glasses already so wearing two pairs gets annoying really fast.
