AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › A bit frustrated...65S64 vs. ST60
post #1 of 3
Got my 65S64 from Costco set up a week ago. I do not have many hours on it but so far my picture quality is OK. Maybe I was expecting a bit more. Hopefully, that will improve with age and Fairchilds settings.
My question.......I have 90 days to return to Costco. At this point I do not plan on doing so but if I did I would spend a bit more to get the ST60.
Is their a significant difference in the PQ of the ST60 vs. the S64?
My room is very dark. Only watch movies and TV. No gaming.
Thoughts??
post #2 of 3
CNET gave the ST60 5 stars and its Editors Choice Award. I have the ST50 and my neighbor has the ST60 and they both look great with his ST60 maybe being a little sharper. Apparently the ST60 does have some input lag issues but if you’re not a gamer this shouldn't be a problem. From what I read, I don’t think you can go wrong with either the ST60 or S64. Given you have a 90-day return widow you could give it a couple more weeks before making a change.
post #3 of 3
What picture settings/mode are you using on your S64 ?
