AVS › AVS Forum › Audio › Speakers › Please help with speaker installation
post #1 of 4
I'm renovating an apartment and making one room into a music listening and TV/movie watching room (I'm reluctant to call it a HT as I don't think it rises to that level).
I was all ready to go with a a 5.1 wall mounted speaker system (like the Energy Take) when I realized that I'm having lighting soffits built around the upper corner of the room -- and I could put speakers in there.
The soffits are 10" high and 11" deep.
Can someone please help me from there?
Is this a viable solution? Can I get good quality surround sound this way?
Should the speakers go on the underside of the soffits or the vertical face?
All suggestions (relating to this question, of course) would be very much appreciated.
Here's a picture of the front (where the TV will go -- not the channel in the wall for data/video/power) and the rear (where more speakers will live).
Thank you!
Rear:
Front:
post #2 of 4
That might not be a bad way to go with smaller speakers. Especially if you don't want to open up walls to run wires. On the other hand, it looks like you have plenty of sheet rock work going on in there anyway. You really might as well run wires to the optimum speaker locations and have the sheetrocker patch the openings when they rock the soffits. That is what I'd do. You only need a couple of holes to run wires to locations suitable for speaker stands.
post #3 of 4
Thanks very much for the input.
Channeling the wall was already in the plan so the speakers can be mounted on the wall (about 2/3 of the way up is the idea, unless a different height is recommended???).
Stands aren't an option with 3 kids and 2 dogs and clumsy people traipsing around.
I should have been clearer about the idea: If I can mount the speakers entirely in the soffit above, then they won't be visible and the Mrs. will be a tad happier (plus it'll be a little cooler).
I guess the question then becomes, how much sound quality would I lose by putting the speakers in the soffit in the best possible way? And, what would that best way be?
post #4 of 4
Any other ideas/help/suggestions out there?
  Back to Forum: Speakers
