AVS › AVS Forum › Home Entertainment & Theater Builder › Outdoor Theaters › Recommendations for a 40" - 55" inch TV outdoor column mount under a covered outdoor patio
post #1 of 2
I am having a covered outdoor patio built and want to amount a 40" - 50" TV to a brick column. I will need the TV to rotate and tilt (mounting it fairly high).
Looking for suggestions as to what is a good reliable brand and can withstand the outdoor elements (it will be under the covered patio but will be exposed to humidity, etc.)
Thank you.
RobertTX
post #2 of 2
Sunbrite TVs are designed for outdoor installs.
If you hire someone, he can find a case for a cheaper TV. These are usually for commercial installs (hence the pro rec). Case has heater and/or blower.
If you dig, you might be able to come up with a solution on your own.
  Back to Forum: Outdoor Theaters
