AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Why do my home movies on bluray look better than the same home movies on hard drive?
post #1 of 10
For years now, I've been downloading my Canon AVCHD home movie footage to Final Cut Pro (first 7, now X) and then burning the resulting project to Bluray via Final Cut's "Share" command. The resulting blurays looked stunning. As of late, however, I have been moving from burning to bluray to burning to hard drive (for an XBMC home media server) and the resulting footage is always, for lack of a better term, muddy. Does anyone know how I can retain the crisp high-def look I see on the blurays? Any help appreciated!!!
post #2 of 10
What are you playing them on? The files should be identical assuming you rendered them to the same coded and spec.
post #3 of 10
Very likely, they're being compressed onto the drive.
post #4 of 10
I'm displaying them on a 55" LED TV. The bluray is playing through a Sony bluray player and the hard drive version plays through a Mac Mini using XBMC. I would have thought they would look identical, especially since I used the "Master File" setting to make the hard drive version, but they do not. The hard drive version has more of a "film" look and not in a good way. Colors not quite as saturated, action not quite as smooth. Perhaps the fault lies within the settings of the Mac Mini or the XBMC interface, but I'm just not sure. Any thoughts?
post #5 of 10
Both using the same HDMI input on the TV?
Bill
post #6 of 10
I'd try a different playe on the Mac. What is available? MPC-HC is about the best on Windows. Do they have a Mac port? If not, VLC might be an option.
post #7 of 10
Bill
Yes. Good question, though!
post #8 of 10
I tried Quicktime player and it didn't look any better.
post #9 of 10
I suspect that your TV is applying processing (sharpness filters etc) to the Bluray player input, but not to the PC input. This is causing you to think that the PC input is 'muddy' whereas in reality it is the more correct picture.
post #10 of 10
If your TV is running through HDMI / DVI from your PC, very likely you'll need to check your Advanced video settings (Intel graphics or AMD). Make sure running RGB (4:4:4), not YCbCr (4:2:2). The difference in picture quality would be very noticeable. This worked for me, when I first connected my laptop to a flat-panel HDTV, via HDMI / DVI.
Edited by L33TX43RT - 9/16/13 at 8:13am
