AVS › AVS Forum › Other Areas of Interest › Camcorders › How 4K and RAW work -- Sony's explaination
post #1 of 2
On Board With 4K
post #2 of 2
Here is the new Sony NEX-FS700R E mount 4K camcorder :
Sony is pleased to announce two new professional NXCAM camcorders, the NEX-FS700RH and the NEX-FS700R. Both models feature Sony’s E-mount lens system and a 4K Exmor Super35 CMOS sensor and now come with Version 3.0 firmware pre-installed, enabling 4K/2K RAW recording on an external compatible recorder. The firmware update also includes the popular S-log2 gamma mode which gives a wider dynamic range, even for HD productions.
The NEX-FS700RH comes with the motorized SELP18200 (f = 18-200mm, F3.5-6.3) zoom lens. The inbuilt zoom control on the camera grip enables users to combine smooth zooming effects with the stunning shallow depth of field control offered by the large format sensor.
The new NEX-FS700R/RH also offers 4K/2K RAW super slow motion when the NEX-FS700R/RH is used together with the optional HXR-IFR5 interface unit and AXS-R5 RAW recorder. This combination allows up to 120fps 4K RAW recording (four seconds) and unlimited continuous 240fps 2K RAW recording on the AXS-R5 recorder.
http://www.broadcastermagazine.com/pressroom/productDetail.aspx?id=12009
  Back to Forum: Camcorders
