AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › what is the STC of ultralight drywall?
post #1 of 11
How does it compare to standard drywall?
I goofed and bought the ultralight instead of the regular, wondering how much difference it is and worth loading,unloading,reloading,andreunloading
post #2 of 11
you should be using two layers of 5/8 drywall. take back the 1/2 inch light weight.
post #3 of 11
Fwiw it was 5/8 lightweight, still necessary to bring back?
Or together with the green glue and 2nd layer is it reasonable that it will work
post #4 of 11
if you are putting in the investment to do everything is correct I wouldn't skimp on the drywall - I think it's something like 30% lighter isn't it? That would be less mass at each layer. Do it once and do it right
post #5 of 11
If I recall correctly, STC only measures down to 125 Hz. Home theatres have (or should have) significant sound energy below that down to 30 Hz and lower. And that is where the additional mass makes the big difference, at the low frequencies. So STC is not the number you should be using here.
Send back the lite drywall, and get the 5/8" fire-rated (heavy) drywall.
post #6 of 11
Ok I'm convinced thanks
post #7 of 11
Careful. Sheetrock brand does have firecode X 5/8" drywall in an ultralight variety. It weighs just a hair more than traditional 1/2"
post #8 of 11
Just had a conversation today with my local drywall supplier. They can't can't get anything other than lightweight 1/2 now. But their 5/8 is still heavy.
post #9 of 11
I figured that would happen. Ted was seriously disappointed when I didn't return my shipment of ultralight, but I decided to make do (especially since I was/am building with two layers plus OSB) The website says "up to 15% lighter" than traditional firecode X. 5/8 times 85% gives just over .5, so it's still about 6% heavier than traditional 1/2, and for 99.99% of their customers, the light weight is a great selling point - so why would they keep making the old stuff unless the costs were seriously different (and they're not).
post #10 of 11
Lighter means less shipping costs, so we get less for a premium price and we are being told it's better.
post #11 of 11
Just finished taking down old wall. Tomorrow putting up regular 5/8 inch
