AVS › AVS Forum › Display Devices › Flat Panels General and OLED Technology › Advice on size and picture quality (plasma/led)
post #1 of 6
I'm replacing my 106" front projector (Epson 1080UB) with a flat panel as I move into my new place.
My viewing distance in the new place is the same as now. About 12-13'.
It should also be noted I don't watch my front projector a lot and instead usually watch a 58" Panasonic V10 at about 9' ( which will be going into a different room with a now 14' viewing distance (so will not be main home theatre).
Picture quality is very important to me, and so I've been seriously considering the Panasonic 65VT60 for the 12-13' distance. However, I'm wondering if maybe for the same price go with a 70 or 80" LED instead.
I'd like your advice on if you think I'm better of with 65VT60 or something larger but with likely less pq. If I get the Vt60 will I regret the size for the viewing distance?
If you suggest a larger led is best, could you let me know which ones you think would be about the same cost as the 65VT60?
post #2 of 6
I would go with the 65VT60 plasma, as that will always give you a better picture than pretty much any LCD/LED display.
At 13' its not too far away. Not ideal, but not too far either...
Also, if you have any off-axis viewers, plasma will not degrade the image for those viewers either which is very important.
Good luck with what ever decision you make!
post #3 of 6
Ok, let's assume for a sec that I may entertain going again with a front projector and 106" screen. Would you still go with the 65vt60 for the pq or would there be a projector in the vt60s price range that would be good enough given the fact that you could get that larger image?
post #4 of 6
For budget projectors (or any projector for that matter), I'd start looking here:
http://www.hometheater.com/content/top-picks-projectors
Those guys know what they're talking about, and there are some very good projectors for under $4,000, though none will match the contrast and black levels of a plasma flat panel (even the best ones), but that just the nature of a projector system...
post #5 of 6
Ask yourself if you really want to lose significant "theater feel" by going from over 100 inches to 65 inches. I see those 70/80/90 inch LCDs all the time and while their PQ is poor compared to plasmas, at least they have that "theater feel" simply because they are humongous. I am not much of a movie watcher so that theater feel is not really important to me, but I would seriously give second look at those Vizios and Sharps if I were one. I know it's a difficult decision. I for one would be very sad parting away from those delicious Samsung F8500s and the VT60s.
post #6 of 6
Yeah, I think it's going to be a 65VT60 (found a good deal up here in Canada for it). I struggled with the decision hard, but ultimately I'm way to critical of pq to go with something that isn't up-to-spec.
I need to be wowed by pq.
