AVS › AVS Forum › HDTV › HDTV Technical › Mitsubishi TV Resets Input During Channel Changes
post #1 of 3
Mitsubishi TV 82'' screen turns black and flashes the input in the upper left corner when changing cable channels. HDMI 1.4a connection from Cox Cable box into a Denon 3313 CI and then an HDMI 1.4a to the TV The TV acts as if it was changing the input on every channel change. Duration is approximately 5 seconds plus the time the it take for the cable box to do its digital change.
What the heck is causing this? How do I fix it?
post #2 of 3
Try setting the cable box video setting (and Denon?) to a fixed video output resolution (I.E. 1080i)
post #3 of 3
I will give it a try shortly. This is for my father's tv so I will have to run over there to mess with it. Thank you for the advice. I will let you know if it works.
  Back to Forum: HDTV Technical
