AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › remote av location help
post #1 of 2
The foundation for our new home gets poured this week. Before I know it will be be time to run all of my network, security, and any A/V wire.
The way our living was designed there is pretty much only one place for the TV, about the fire place.
Ideally I would like to have all the A/V equipment in another area that feeds the wall plates behind the TV.
I think the only option I have is to use some space in our closet under the stairs, approximately 30 feet away from the TV. I will also be mounting four in-ceiling speakers and possibly in in-wall sub.
  • What and how many types of cable should I run
  • Will I run into any distance limitations on the various types of cable needed
  • What have you guys used for wall plates (do you have any pictures)
  • Will I need to vent the closet area.
Is there anything else I am forgetting or should plan for?
Mike
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), default quality
http://i65.photobucket.com/albums/h235/abernut/Home%20Security/1stFloor2.jpg
post #2 of 2
woops.
That was supposed to read... "Above the Fireplace"
  Back to Forum: Home A/V Distribution
