AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Setup 4 speakers on a stereo, impedance ?
post #1 of 7
Hi everyone,
Victor, 24 from France.
I have a quick question that has probably been asked thousands of times, and i've looked online but I still can't quite figure out if I can do what I wanna do.
I have a stereo that came with 2 speakers.
On the back of the stereo, impedance is, i quote : 4-16ohm.
I have two 3 ohm Speakers and 2 8ohm speakers.
Question : is there a way I can have all those speakers plugged in the stereo ?
Thanks in advance,
Victor
Edit : no idea why I said I was 24, I'm 26.
post #2 of 7
It's alright. I'm nearly 70 and I try to forget my age all the time. Putting two speakers on the same output will halve the impedance. So you would end up with a 4 ohm speaker and a 1 1/2 ohm speaker. Will that work? Maybe. Try it. Don't apply much power and see if the amplifier overheats. If it doesn't you will probably be OK.
post #3 of 7
Thanks for the reply.
So :
On the left output, I plug in 2 speakers, one 8ohm and one 3 ohm, so impedance on the left is 4+1 1/2 = 5.5, which is in the range of my stereo (4 to 16 ohm).
So it should work. Unless calculations should be made per speaker instead of what I jus did, per output......
I'll try tomorrow, speaker by speaker...slowly, gently...
post #4 of 7
Two 8 Ohm speakers in parallel will result in a 4 Ohm load.
Two 3 Ohm speakers in parallel results in a 1.5 Ohm load.
An 8 and a 3 in parallel results in a 2.2 Ohm load.
Safest bet is to put an 8 and a 3 in series for an 11 Ohm load.
post #5 of 7
Alright thanks !
Just to be sure, in series = plug 2 reds in the red socket, and 2 blacks in the black socket. And same on the right output. Correct ?
post #6 of 7
No.
In series, plug the red from one 8 Ohm speaker into the red socket, plug the black from one 3 Ohm speaker into the black socket, connect the black form the 8 Ohm speaker to the red on the 3 Ohm speaker.
post #7 of 7
Just did that, works fine. Good power, no overheating after 5-6 hours a mid volume. Thanks thanks guys
