AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Used Epson 3020 $900 vs New Epson 2030 vs New BenQ W1070
post #1 of 3
If given the choice which projector would You chose. The 3020 has around 500 hrs on it and is covered by warranty. I have some light in the room I am going to use the projector. I will watch 3d blurays on it.
Edited by brtnelson - 9/18/13 at 7:27pm
post #2 of 3
Bump.
post #3 of 3
Hi brtnelson, First how are you getting a warranty on the used Epson. Do you have problems seeing RBE on DLP. The Epson's have lens shift and Benq doesn't. For 3D I would go with the Benq as long you don't see RBE. Also take a look at this thread it will have a lot of info that you are looking at. benq-w1070-vs-epson-2030-direct-comparison-yes-i-have-both
