AVS › AVS Forum › Video Components › Home Theater Computers › Can't get blurays to play after windows 8 "up"grade
post #1 of 11
Hi there!
I recently upgraded from windows 7 (where blurays were working fine on total media theatre 6) to windows 8 and suddenly I cannot play bluray at all on powerdvd, totalmedia theatre, or corel windvd pro.
I've tried all 3 software, reinstalled each one, and updated each one to their latest edition. None work.
I've also tried multiple disks (planet earth, life, and frozen planet) and none work.
Lastly, I updated my nvidia drivers (I have a gtx 240) to the latest edition.
For windvd & powerdvd, nothing happens when I press the play button. For total media, the first 5 seconds (usually the FBI warning, and then a few seconds of the intro video) will play and then it'll freeze and stop playing, returning me to TMT's opening screen.
Since 3 different software all failed, my guess here is that there's something else wrong. However, after hours of trying everything I can think of, I cannot figure this out.
If you have any ideas I'd enormously appreciate your help here.
Thank you in advance!!
post #2 of 11
Did you try asking on the support forums of the vendors respectively?
While its weird that it affects all of them, it might still be a simple bug in their software.
post #3 of 11
Did you actually upgrade from Win7 to Win8 or did you do a clean install from Win7 to Win8. If it was an upgrade then that might be your problem.
post #4 of 11
Good idea - I'll give that at try as well. Thanks for the response.
post #5 of 11
Nope - it was a clean install :/.
post #6 of 11
Try replacing your video drivers. If you use ATI, download their official cleaner tool and use it prior to reinstalling the latest drivers from them.
post #7 of 11
Hi Cybersage,
I installed the latest nVidia drivers with no luck. Any other ideas?
Eric
post #8 of 11
Which version of Win8 did you install: Standard, Pro, or Pro+WMC?
If you don't have WMC, you may be missing some of the key codecs.
FWIW, I'm on Win8 Standard, and I installed MediaPortal as my DVR solution, which came bundled with the LAV filters/codecs. Works great.
But if you're already on Pro, likely worth the $10 for WMC.
post #9 of 11
Both PowerDVD and WinDVD have their own codec support built in. They don't rely on OS codec support. $10 for WMC won't buy you much (mainly MPEG2 codec support in OS).
post #10 of 11
I would not buy the WMC app if all you want is the codec. I bought it for all the goodness that WMC brings as a front end.
post #11 of 11
Thanks FoxBat - yes this is my understanding to.
