AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Anyone tried This?
Anyone tried This?
post #1 of 7
It's a Winegard GS 2200 shaped like nothing I've ever seen- like an airplane!. The local TV guy has one that guarantees it's the one for this area. He wants $89.00 and just found i can by it for less than half that shipped.
post #2 of 7
It may be a good antenna for suburban areas with a strong signal, but not necessarily the best choice.
post #3 of 7
The Wingard Sensar has been around for a long time and is most commonly seen on RVs and travel trailers.
It's generally a fair VHF antenna and a very lousy UHF antenna.
post #4 of 7
I think they now have an add-on element to help improve the UHF. Wingman i think.
post #5 of 7
I sure hope you're wrong on this- I just ordered it last night and the Wing. I based it on these reviews and the guy in Atlanta sounded a lot like me. Here are some of the reviews.
http://www.amazon.com/Winegard-GS-2200-Sensar-Amplified-Antenna/product-reviews/B001DFVJ6K
http://www.amazon.com/Winegard-GS-WING-Sensar-DTV-Upgrade/dp/B002DPTQXW/ref=sr_1_2?s=electronics&ie=UTF8&qid=1379681950&sr=1-2&keywords=winegard+wingman#productDetails
post #6 of 7
I hope this antenna will work. It is good for what it is, but maybe not the best choice. I still think there is some other technical problem of some sort here. But I agree you may have very strong signals that could be overloading the tuner or causing multipath or reflection problems. Extreme cases like this prevent the tuner from decoding a signal. This was a problem that was experienced in Chatanooga, Tn. due to extreme multipath caused by the hilly terrain. The solution was to place the antenna inside a garbage can. Trip in Va. posted about this a year or so ago in the Chatanooga thread. But hopefully your new antenna will work.
post #7 of 7
Tyler I hope it does too and hopefully will find out the first of net week!smile.gif
