AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Smooth Scrolling Rotary Volume Wall Control?
post #1 of 5
Is anyone aware of a wall mounted volume control that has a smooth rotary dial? As it is it seems every one that I have found is a 'notch' type rotary dial, such that there are 10 discrete volume levels etc, rather than a traditional smooth rolling type. Thanks!
post #2 of 5
They are notched for a reason. The notches are where the volume pot makes contact with the rotary pin, giving you the volume you want.
You could try a slider type of volume control.
post #3 of 5
Generally they step because they are NOT simple potentiometers as might be used for the volume control on a electronic device but are instead multiple position switches selecting between taps on a transformer.
These devices allow you to connect multiple sets of speakers to an amplifier and insure that amplifier sees a suitable impedance.
If you only need to control the volume when connecting a single set of speakers to an amplifier there is a device called an L-Pad which is usually not stepped.
post #4 of 5
I would assume that if manufactorers are able to produce sliding volume controls, the same scheme could be adopted to a rotary dial?? If not, how does a sliding control work.....Maybe varying the load position on the windings? Seems like that could be done on a rotary dial also..
Edited by theeld - 9/20/13 at 10:03am
post #5 of 5
Well I only checked in a few places for slider types but the ones I found were stepped as well.
But there is so much out there who knows what you might be able to find.
I prefer the stepped ones myself - easier to return to a known setting.
  Back to Forum: Home A/V Distribution
