AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Think I made my mind up. Couple ?s Denon 1613/E300
post #1 of 2
Well after some re search I think I have made my mind up. I am in bewteen the 1613 and e300. Is there any difference in the two. I know the e300 is the newer model but any changes? Is it worth the $30 price jump. Plan on getting refurb from a4less. Also my main concern is the network wired on both of these or will it pick up my wireless? This could be a problem since my router and everything is wired up downstairs. Internet is pretty important for firmware updates and pandora. Thanks for the input
post #2 of 2
Please refer to my post #7 in the Denon AVR E/X Owner's thread linked below ...
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#post_23139002
Also, using a router as a bridge is possible as long as you are using a robust bridge router.
Router
Cisco WRT-100
Cisco E3200
Linksys BEFSX41
Netgear N600 3400v2
Netgear WNDR-3800
Netgear WNDR4500
Airport Extreme
Bridge (connected to AVR provides wireless connection to the home's wifi router)
Cisco WRT-54G
TRENDnet TEW-640MB
Airport Extreme
Airport Express
Linksys WET610N
Netgear WN2000RPT - 4 port
Netgear WN2500RP
D-Link DAP-1522
Other
Netgear XAVB5004 Powerline Network Adapter (4-port) (on AVR set Network Standby/IP Control to ON/Always ON)
D-Link Powerline Adapter
Belkin Video Link 3 (w/static IP)
D-Link 8-Port Gigabit Switch (DGS-1008G)
