AVS › AVS Forum › Display Devices › Display Calibration › Which one of these?
Which one of these?
post #1 of 4
Which calibration disc do you guys feel is the better of the two if any? I"m looking to calibrate our 55 inch Samsung LCD tv's. I have been looking into the WOW and Spears & munsil disc and didn't know which one would be better for me to use.
post #2 of 4
How elaborate a calibration are you intending to do?
They're two free ones that you can download from AVS. AVS709 and Mascori's
post #3 of 4
This will be the first time ever doing something like this. I guess I would like to do it the best I can. I was just reading on the net about these two disk.. If I read right the spears & munsil disk also does the surround sound also.
post #4 of 4
Greetings
In order for the test disc to help you with your audio, you will need a sound pressure level meter. Discs can't magically sprout hands to do this for you.
Go with the S&M disc.
You are just doing user controls anyway.
regards
