AVS › AVS Forum › Audio › Speakers › Best speakers for a 80 square meter room (below 1000 uk pounds)
post #1 of 41
Hi,
I am a newbie looking to acquire an av receiver (opened a thread in receiver subforum) + 5.1 speakers to be installed in a huge 80 squae meter room (870 square feet).
As a reference, ceilings are high and would average 3m high (it is a dormer window with max 5m in the middle and lowest of 2m at the front and back)
I was looking at the Onkyo 616 and 626 as receivers and was wondering which speaker bundle (5 speakers + subwoofer) should I buy with enough power for such a room (I dont know if the key component for power are speakers or receiver)
I was aiming to spend c. 1000 pounds in receiver + speakers but will spend more if necessary to have a good sound quality.
Many thanks,
Pablo
post #2 of 41
fwiw, where do you live? that's a pretty large room to fill with good sound and a small budget. I would opt for a 2.1 system and expand when funds are available. I would also look into putting your money into a good sub or (subs) and less on the electronics (avr). imo look into higher efficient speakers to help fill that size room with sound.
post #3 of 41
Look at speakers with high sensitivity ratings. Definitely over 90db, and even higher than 90db would be better.
Then for that size room, you really need a large 15" sub at the very least, which is costly. Subs see the whole room, and even a powerful 15" sub will be challenged in that size space. Unless you can locate the sub a few feet from where you sit, the bass will not be very impactful.
post #4 of 41
Originally Posted by paramio View Post
Hi,
Many thanks,
Pablo
Your really asking too much for a $1.000 budget to fill your space. That's not even enough for a single subwoofer to fill your space.
I would suggest investing a lttle more. Like $5,000 more for a room fillling good sound.
post #5 of 41
Thanks for the advice
Room is mostly empty (pictures and bookshelves) and not carpeted (does this affect a lot?)
I was hoping to spend 1500$ but can go up if necessary.
wOULD AN oNKYO nr616 + 4 BW 686 + 1 HTM-62 + 1 ASW-608 (b&w speakers + sub) work decently for this room?
I am really not looking for high playing volume but for clean audio (maybe I should work on the room aoustics as well)
post #6 of 41
fwiw, yes some throw rugs on floors and walls would help a lot to help with sound reflections. room acoustics is probably the most important overlooked aspect in how good your room will sound. as for why I asked where you lived ( obviously not in north America) is to get some ideas in your part of the world the best options for members here to recommend a nice system in your budget without spending most of it on shipping costs and other tax duties. as for the b&w system you mentioned imo could be bettered as the bookshelves are only 84 db sensitive (in you size concert hall I would look at something 90db or greater.)and that 8" sub will do you no justice in that size room a waste of money imo.and as for the onkyo avr don't know how much it goes for where you live. imo with that kind of budget I would look at refurbished or open box or discounted last years models(look for models with room correction for ex. *audyssey* this will help give you best sound from speaker and sub placement) to save on whats more important your speakers and sub.
Edited by smasher50 - 9/22/13 at 10:32am
post #7 of 41
^^ Agreed.
90db (or more) sensitivity would help for that size room.
And an 8" sub? We'll you'd have to sit on it or be 2 or 3 feet away for it to be of any use. For a sub, I would recommend contacting BK about one of their subs or SVS Sound (they have UK distributors) about what sub would be best for your room and use.
post #8 of 41
Google GIK Acoustics. Get the combo #1 for around $550. Treat your first reflection points. Your room is about 25% of the chain.
Its always Speaker first, then your room, then your amps/preamps/dacs/cables etc.
post #9 of 41
Many thanks to all.
I am from Spain but can buy any equipment in the UK if needed.
How can I check the db sensitivity? Any sub + speakers above 90db that you would recommend?
Also, what are the first reflection points?
Many thanks again
post #10 of 41
Most manufacturers list sensitivity specs for their products. Some are a little more optimistic than others, but still a good place to start.
post #11 of 41
Many thanks to all.
Many thanks again
Dude, you really have no options with $1,000 budget for 5.1 system in that space. If you spend about $2000 -$3,000 more alot of members would be able to help you out more prabably.
post #12 of 41
I think I would have to disagree look at PBS alpha series they are a great bang for your buck. And they make great subs as well
post #13 of 41
You do not have to spend 5 k to fill that space that is crazy do some research hsu makes great stuff. Money is not the way to audio nirvana. If everybody had to spend 5 k to get good sound audio would not exist especially this forum. I'm sorry that's the worse advice if ever heard your emplying money equates to enjoying our hobby NOT TRUE AND BAD ADVICE!!!
post #14 of 41
Really? What is your system?
post #15 of 41
post #16 of 41
System for my room.
Room dimension is 13 x 14 x 10.
GIK Acoustics room treatment combo #1.
PS Audio Power conditioner -> Marantz as transport -> Monarchy DIP Upsampler -> Eximus DP-1 DAC -> Job 225 Amp -> Vapor Cirrus Black w/ Amor RAAL upgrade
Gonna run it with custom VH Audio interconnects and cables.
post #17 of 41
You really think HSU speakers will give you "good" sound? LOL.
post #18 of 41
^^ So just to be absolutely crystal clear - as of today, do you actually have that system set up and playing in your room? Yes or no.
post #19 of 41
What would you recommend at around c. 2000$?
post #20 of 41
fwiw, I would look at the monitor audio bx series speakers in your budget. seen the bx5's for 500 uk dollars; the bx2's for 249 uk.d and the bx center for 149 uk.d. also seen the denon avr x1000 for 314uk.d just don't know what shipping costs to where you live would total and since svs sounds has overseas retailers I would maybe look into a svs pb12-nsd sub just a recommendation
Edited by smasher50 - 9/23/13 at 1:45pm
post #21 of 41
Without a doubt go for 5.0 Tekton M-Lore system. Prabably will be the best thing to fill your space.
post #22 of 41
post #23 of 41
Many thanks.
The full Monitor audio bx series you suggested (over 90db) costs me just above 1000 euros so great for my budget and have read great reviews about them.
The problem comes with the svs pb12-nsd sub, which costs another 1100 euros here in Spain.
Any other sub model you would recommend?
I am really going to buy what you recommend me here as retailers here in Spain cannot be trusted, most of them didnt even know what db efficiency was when I asked them...
post #24 of 41
Have just read great things about these speakers but they dont ship / dont have a distributor here in Spain...
Thanks anyway
post #25 of 41
fwiw, just quickly looking whats available in Europe I would also look at the svs sb12 nsd $549 amazon uk or the bk monolith plus $549 from bk subwoofers direct
post #26 of 41
SVS 12 is okay but just to be safe I'd go for the Hsu VTF-15H.
Don't try to get everything at once. First just go with 2.1. Then gradually add the center and the sorrounds.
post #27 of 41
dude pleaseeeee, the op lives in spain . hsu does not have any retailers in Europe and they don't ship outside north America and if they did it would cost $400 to ship there. so please stop trying to get attention with your ridiculous responses. everyone in these forums can see right through you and what your trying to do
post #28 of 41
We are kind of spoiled here in the US by the Internet direct subwoofer vendors we have. The closed thing to them that I know about in the EU is BK Subwoofers direct in the UK: http://www.bkelec.com/HiFi/Sub_Woofers.htm The Monolith DF did well in some subwoofer measurement tests I have seen.
I have no idea what they would charge to ship to Spain.
post #29 of 41
Oops. Completely forgot about your location. My apologies. If thats the case, then you really have no option then go with the above recommendation BUT get a 15 incher just to be safe.
LOL. I will say this once. I am not that guy SearchofSub.
post #30 of 41
iwill say this once. you are that guy searchof sub
  Back to Forum: Speakers
