AVS › AVS Forum › Audio › DIY Speakers and Subs › SEOS Fusion 10 Pure Assembly
SEOS Fusion 10 Pure Assembly - Page 2
post #31 of 36
Cogeng, what did you use to line the cabinets with and how much? I am building 3 Fusion Pure 10's for my theater too and not sure what to use
post #32 of 36
I used a bunch of polybatting, just glued it on with left over wood glue. It came up to about even with the bracing, so maybe 1.5 - 2 inches thick. LTD suggested using pink fluffy, and I have seen people use recycled cotton as well as egg crate foam.
post #33 of 36
Cool. Thanks for the quick reply. Did you put any on the bottom of the cabinet? I read we are not supposed to block the ports.
Sorry, didn't see that earlier in the thread.
post #34 of 36
I actually did put some underneath the ports but not extending out behind them, just to where the ports opened up inside the cab.
post #35 of 36
Thanks for the info. Great job by the way, speaker looks really good.
post #36 of 36
