AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo tx-nr609 + Samsung UN55F7100 Smart TV audio
post #1 of 6
All,
I just purchased a new Samsung UN55F7100 LED TV and I am having problems with the Smart TV audio though the receiver. I have the latest firmware on the Onkyo 609 and the Samsung TV. I have RIHS set to "on" and ARC set to "auto" on the Onkyo. Do I need to have a optical cable between the TV and receiver? Any help would be great! Thanks!
Dave
post #2 of 6
Hi FeeArrow, to use ARC make sure the HDMI cable is plugged into the TV HDMI -2 input. Also in the Samsung AnyNet + menu set External Speaker to from "Tv Speaker" to "Receiver". You may have to power off and on the components.
post #3 of 6
JChin,
Thanks for the reply! I moved the HDMI to input 2 and now it automatically changes the Onyko receiver to TV/CD and I do not get audio from my Cable/SAT. Any ideas? Thanks again!
Dave
post #4 of 6
Note that ARC (audio return channel) is to pass audio from tv to receiver.
What other source do you have and how are they connected?
If you have a HD cable box connect it directly to the Onkyo 609 HDMI (CBL/SAT) input.
post #5 of 6
JChin,
I have all my devices connected through the Onkyo 609:
PVR is on CBL/SAT 3
Blu-Ray is on BD/DVD 1
Xbox is on Game 4
PC is on PC 5
and I have "OUT" connected to the Samsung TV on HDMI 2 now.
Do I need to connect an optical cable from the TV to the receiver? Thanks again for the help I really appreciate it!
Dave
post #6 of 6
Originally Posted by FeeArrow View Post
JChin,
Dave
That's the negative of ARC, it automatically switch to TV/CD input. If you're not using tv apps then turn off AnyNet+ and ARC (and ARC on Onkyo). The Blu-Ray player and Xbox most likely has the same apps as the tv.
JChin,
PVR is on CBL/SAT 3
Xbox is on Game 4
PC is on PC 5
Dave
Optical cable is not needed from tv to receiver.
