AVS › AVS Forum › Industry Area › HDMI Q&A - The One Connector World › Monoprice Redmere vs Amazon High Speed - HDMI Cables.
post #1 of 7
Monoprice has this forums support but Amazon has the scale, who makes the superior cable and how does one even compare?
post #2 of 7
How is the 4K TV working out?
As for the answer to your question, as long as you get a High Speed HDMI cable (must say so on the advertising) and it's certified, then you have the best cable you can buy. Even if you spend more money, the bits are the same coming out.
The only variable is build quality. We can discuss that, but I need to know how long of an HDMI cable you need?
Just remember these are digital cables, so as long as you don't get bit errors, you're golden.
post #3 of 7
Amazon has little in the way of quality control more or less which should always be of concern.
There are cables out there from multiple vendors which hit price points all over the place from just a couple of bucks to hundreds of dollars for a 2m cable. Monoprice is respected across the Internet community because they were one of the first to blow the bubble off of high HDMI cable pricing, and have maintained that mentality since their inception. The reviews on their site for each and every cable speak to this fact.
On shorter lengths, I've used the ultra thin cables from Parts Express as a good alternative to Monoprice.
I have never purchased a HDMI cable from Amazon, and I've heard some horror stories which make me worry, but for the most part, I would just read the reviews and decide from there.
post #4 of 7
Amazon have their own brand of cable which works thus far, I will try a Monoprice Redmere from the Time Warner Cable Box to the 4K TV.
post #5 of 7
The 4K Television is stressing me out cause I had the 4K resolution working perfectly with SwitchResX, then I decided to Tweak it and lost all progress!
I have measured from the Cable Box to the TV, 8FT. My TV Room, is 11.545FT and 14.709FT, 170Ft Squared roughly.
post #6 of 7
8 Feet means you are in good shape with any HDMI cable that is High Speed. At 8 ft I would recommend against the Redmere cable unless you really need a thin cable.
The reason is that the Redmere cable is an active cable that restores the waveform at the destination. 8 feet isn't long enough to really need an active component and is just one more item that could fail.
Instead try one of the Monoprice passive High Speed cables. Such as...
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024008&p_id=3993&seq=1&format=2
This cable also has the advantage that it should work with HDMI 2.0.
This should also work:
http://www.amazon.com/AmazonBasics-High-Speed-HDMI-Cable-Meters/dp/B003L1ZYYW/ref=sr_1_2?ie=UTF8&qid=1379966731&sr=8-2&keywords=hdmi+10+foot+high+speed
If you were approaching 25 feet, I would have a different recommendation, but at 8-10 feet you should have plenty of choices for not a lot of money.
post #7 of 7
Thanking you for your comprehensive reply.
