AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 3312
Denon 3312
post #1 of 4
I have a 3312 Everything I play through my Micca player mostly MKV movies only plays DTS neo..It used to select Dolby Digital or whatever surround the movie was.I can't see anything that would have changed..Can anyone help.
post #2 of 4
The AVR can only play what it receives. Look for a setting on the Micca player.
post #3 of 4
You were right as usual..HDMI had to be set to RAW on the Micca Player.Thanks for your help.
post #4 of 4
