AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Using KDL-60R520 in Europe
post #1 of 3
I got this TV from Costco.ca. The TV itself is awesome but strangely it says 120V and 60Hz only. I have a old Sony LCD and a LG Plasma and two smaller Samsungs. ALL are multi voltage and multi frequency (meaning 110-240V and 50/60Hz). This is the first TV that I see as a 120V and 60Hz only. I called customer service but they seemed clueless and I got the normal "No you cannot as its 60Hz required. Danger Danger........
My issue is that I am moving to Africa and buying a TV there is close to impossible. I have to take one with me. I have a PAL to NTSC converters (HDMI) and I am told that the Satellite receivers there can output to HDMI. Sooo....the only issue is voltage
Has anyone used a 120V and 60Hz TV on 120V BUT 50Hz? Any issues.
There are no motors or so in a TV sot theoretically I feel it should work, but theoretically any switching power supply (like in all flat panels) should be 50/60hz anyway. Why is Sony particularly stating NO YOU CANNOT
Anyone having some actual experience?
post #2 of 3
Anyone?
Does anyone has experience using a 60Hz only TV in Europe with a transformer?
post #3 of 3
You won't have a problem as long as you don't fed 230V AC into 120V directly, without a step-down power transformer.
Power supply electronics are analog nature and will fluctuate regulary, there is yield range of about +- 5% to 10-20% etc.
I use here a 230V/50Hz AC to 110V/50Hz AC, 75W step-down transformer with a 110V/60Hz NTSC DVD player without any problem.
SONY is covering theirs, in case something goes wrong outside the specs.
