AVS › AVS Forum › Industry Area › HDMI Q&A - The One Connector World › HDMI port repair?
HDMI port repair?
post #1 of 5
I believe lightning knocked out one input on my Panasonic viera. Fortunately I have 2 other inputs. Problem is it also
fried the only the VIDEO side of my Sony HT-CT550W home theater. The audio still works. I wonder if there is a reasonable cost to fix just the HDMI part of the unit? No warranty coverage.
Scott
post #2 of 5
What do you consider reasonable?
post #3 of 5
To replace the entire system including sound bar and wireless subwoofer is $300. I'd like to consider around $ 50 is good. I can still use it with a line-in for JUST audio.
post #4 of 5
Here's information on Sony parts ordering:
http://esupport.sony.com/US/p/model-accessories.pl?&mdl=HTCT550W
This webpage might help:
http://www.partstore.com/Model/Sony/Sony/HTCT550W.aspx
It looks like the HDMI function is on a separate board (HDMI COMPL-F13028800), but I can't be sure without a exploded view. The price listed for this HDMI board is over $100 - but, that was at a Best Buy parts store (who knew Best Buy was into overcharging for parts now?)
So, asking Sony or their parts distributor (lower right on the web page) is probably your best bet, if indeed this is the right part to fix your HDMI issue.
However...Since HDMI sends both audio and video as a single stream of data, I don't believe the HDMI processing could be faulty and still allow audio to work. Instead I have to wonder if it isn't the video processor on the main board causing the problem. Have you tried bypassing all video processing (if the Sony has the ability to bypass, it would be a menu function)? Does audio on the TV still work? If not, it could be the HDMI output function (while HDMI inputs is working).
You may end up getting the wrong part if you are not sure of where the failure is located.
Edited by alk3997 - 9/24/13 at 12:05pm
post #5 of 5
I agree with alk3997 - you should be able to just replace the appropriate boards by yourself - sounds like the input board on the Viera and possibly the video board on the Sony? check out shopjimmy.com for parts.
