AVS › AVS Forum › Audio › Receivers, Amps, and Processors › What to select, "small" or 'large" speakers when connecting Anthem MRX to a subwoofer?
post #1 of 3
I got my Anthem MRX 700 installed by a pro when setting up the ARC software 2 years ago. Upon checking the settings, I recently noticed that the selection for the floor standing speakers was set to "large" speakers even when the receiver was hooked up to a subwoofer. Shouldn't it set to "small" speakers when connected to a sub? If so, what shall I do to set the speaker selection to "small" instead of "large"? Thanks.
Gear mentioned in this thread:
post #2 of 3
If it were Audyssey, I would tell you to switch them to small for sure. However, I am not familiar with Anthem Room Correction.
post #3 of 3
You should be able to manually set it to small or large, check with the Anthem guys from the other thread
