AVS › AVS Forum › Audio › Speakers › Speaker Cable - 8 Gauge vs. 10 Gauge
post #1 of 15
Is there really a huge difference in the sound quality between an 8 Gauge or 10 Gauge speaker cable?
The only thing I notice difference is that the 8 Gauge speaker cable is thicker.
Thanks for any advice!
post #2 of 15
Nope.
post #3 of 15
nada,nil,zip,na,nyet....
post #4 of 15
Thanks guys!
Maybe I can save some money if I buy the 16 Gauge speaker cable. The 16 Gauge is pretty thin compare to the 8 Gauge but the sound quality will sound the same anyway.
post #5 of 15
post #6 of 15
Can't imagine where you'd need 8 awg cable for speakers. For that matter, even 10 awg. (unless your speakers are a LONG ways away)
post #7 of 15
It's manly.
post #8 of 15
I can't imagine trying to fit 8 awg in banana plugs or binding posts.
post #9 of 15
Originally Posted by mantaraydesign View Post
Thanks guys!
Use this to find out what you actually need:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
post #10 of 15
You think 8 awg is huge, you should take a look at the 4 awg. Yes, I just found out that they make the massive 4 awg speaker cable. LOL
post #11 of 15
I will give that a try.
post #12 of 15
Originally Posted by Chu Gai View Post
http://www.roger-russell.com/wire/wire.htm
Great information and thanks!
post #13 of 15
I have another question.
When you connect the speaker cable to the back of the speaker, do you use the Banana Plug connector or do you use the bare wire?
Here is a picture:
Processed By eBay with ImageMagick, z1.1.0. ||B2
Again, do the Gold plated banana connectors make huge improvement on the sound quality? Or is it just another hype marketing?
post #14 of 15
You can use whatever floats your boat and that includes pins and spades. IMO, using connectors is a neater and more elegant, if you will, way of joining two pieces of equipment and avoids the possibility that a stray wire causing a short. BTW, not all gold connectors are actually gold and the thickness of the coating does vary. What gold does is provide a surface that is not attacked by chemicals which includes oxygen. Don't overly obsess over the minutiae.
post #15 of 15
I use bare wire, except for my pro-sound gear, which has connectors because I plug them in at the beginning of the night, and unplug them at the end.
They make no difference. Gold isn't a very good conductor, it's used because it won't corrode. That's significant if your system is on a boat or in a house near the ocean, but otherwise, not really.
  Back to Forum: Speakers
