AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Do all of these Component cable 'switchers' boxes have input lag?
post #1 of 4
I was wondering, i only have one set of component cable inputs on my SDTV which i'm using for my retro setup, however i still play wii & DVD's on it via component, but it's a pain in the butt having to constantly unplug and replug them back in everyt ime i want to use one or the other. I have an old school receiver that only accepts RCA. I'd love to get an affordable switcher, but if there's any sort of input lag it's a no go. Not too sure i want to spend the cash on yet another receiver, besides i hear they can also cause input lag(Aside fom audio sync lag) when resending another picture signal. :P
post #2 of 4
Check it out...
Component Video Switcher 4 In 1 Out...
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011007&p_id=3027&seq=1&format=2
Just my $0.05... 👍😉
post #3 of 4
Originally Posted by M Code View Post
Check it out...
Just my $0.05... 👍😉
thanks man! hopefully there isn't an issue with input lag, that would most likely be the deal breaker. Guess i'll have to see for myself.
post #4 of 4
Video delay is usually caused by video processing circuits...
Since your video streams are analog, and the box is low cost there is no or little processing but you will need to try it...
I think it will work fine for your application...
Just my $0.05... 👍😉
