I am in the process of upgrading my HTPC system. Currently using an AMD A-8 and switching to the new Intel Haswell i3-4130T. Is anything going to break if i switch to Windows 8?
Why do you need an HTPC for any of that? There are several streaming boxes that can do everything you listed much cheaper and simpler than a PC.
Netflix will actually improve in Win 8 since you're going from 720p to 1080p. But PCs still do a crappy job with Netflix. The Win 8 Netflix app doesn't even support profiles yet, nor does it support a remote.
Originally Posted by mdavej /t/1492282/are-you-using-windows-8-as-a-htpc#post_23775994
I use Win8 for my gaming machine - it is superior to Win7 for such a use. For my HTPC, I am using Win7 still and see no need to change it. Even though WMC in Win8 is a newer version, the changes are all under the hood and do nothing to aid the user experience.
I presently use Win8 with XBMC on my HTPC. I use it for movie, music and tv shows. I also use that pc to "empty" my dvr with the help of a colossus card and arcsoft showbiz. it is also my bluray ripping machine and media server for the rest of the house.
It works well and it came with the Dell XPS8500SE that I use. I don't feel the need to go back to win7. The only reason why I would even consider going back is if I got tired of XBMC and I wanted to run wmc+mb 2.x on it, which I don't see why I would...
I use Win8 and I like it much more than I had expected. The Metro Netflix app is great and there are a few more apps which are good in the HT. Yes the lack of remote control compatibility is a minus but I get around that with Unified Remote on my phone.
I found a program that resizes the Metro screen and I increased the zoom to 150% which makes it perfect on my 55" and projector screens.
I’ve had a HTPC since 2007. The hardware, now in its third incarnation was running Vista. Last year I received Windows 8 Pro as a Christmas present, and got the WMC add-on for free. As far as WMC goes, there are a number of real improvements going from Vista to 8, but for the OS itself, we are not friends. After 9 months of use, I still get the feeling that it won’t do what I want until I get up and smear my hands all over the big screen, not that it would help. In the end, it’s been worth what I paid for it.
I also run Windows 8 Professional on an i5 Intel NUC. The Intel drivers are better in Windows 8. Improved XBMC stability. Windows 8 also boots incredibly fast on the NUC. Other than that the boot screen tends to look better with XBMC Xperience1080 theme.
Originally Posted by politby /t/1492282/are-you-using-windows-8-as-a-htpc#post_23777536
This is something i noticed as well, the Metro Nexflix app is a huge improvement over the WMC version, which is one of the reasons i wanted to consider upgrading to 8. I wish Netflix would integrate IR remote capabilities into the metro app then it would be perfect but the Metro app was designed for touchscreens, not HTPC users.
Originally Posted by krodami /t/1492282/are-you-using-windows-8-as-a-htpc#post_23790659
I complained loudly about the lack of IR capability in the Netflix App, but having lived with it since Windows 8 came out, I'd much rather use the Metro interface + bit streamed DD+. It also can get the Netflix HD 5800 kbs stream which I don't believe is available through WMC. Metro makes an awesome launcher interface and I have all my HTPC apps (WMC, Netflix, Steam, XBMC, Weather) clustered together and I can launch any of them with the remote (bind the green button to CTRL+ESC and the whole experience gets a lot nicer). I think it's silly to stick with 7 at this point.
I moved to Win8 on my desktop and received a free Media Center upgrade. However, I won't be running it on any of my HTPCs. It's a fine OS, but it didn't bring anything that I needed for an HTPC. I have as many Win7 licenses as I'll ever need and I suppose I'll just keep using it until it stops working. Media Center is on death row as it is and Win8 only moved the execution date up.
Some basic functions like play/pause, volume, etc. work on my MCE remote in the Netflix Windows 8 app. It's not a terrible experience. I use a combination of a K400 and an MCE remote or HippoRemote to do both at once.
I found the differences (on MC) to be negligible.
Some flexibility was lost on Win8 because you can no longer hack the DLLs and some apps relied on that (e.g., channel logos making the EPG 10 rows). No big loss really.
I am very happy on Win8 for one reason: if MC crashes to desktop it will auto-restart by itself, and not just leave me at desktop and force me to get up and re-load the MCE shell. Win7 never did that out of the box. I haven't had to pull out the kb/mouse for many many months now.
Originally Posted by sippelmc /t/1492282/are-you-using-windows-8-as-a-htpc/0_100#post_23794969
To be clear, MyChannelLogos markets their download (donate-only product these days) as W8 compatible. Are you saying the logos work fine, but the EPG can't be expanded to 10?
Originally Posted by sippelmc /t/1492282/are-you-using-windows-8-as-a-htpc#post_23794969
Originally Posted by Dark_Slayer /t/1492282/are-you-using-windows-8-as-a-htpc#post_23795119
That is incorrect. The Version numbers in Windows 8 Media Center and Windows 7 are the SAME. There are only one change in WIndows 8 Media Center over Windows 7. In Windows 8 they removed the option to "Start Windows Media Center when windows starts".
I did a lot of homework on this to make sure on any details and there is NO changes that will effect Windows Media Center in any way with Windows 8. Infact, I suggest people to stay with Windows 7 for Media Center because there has been some issues with cablecards and HDCP in some cases that people have reported. If you have used MC with cablecards, HDCP issues can be a pain the a$$ to deal with.
If your thinking about building a HTPC for WIndows Media Center, stick with Windows 7.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
