PC with HDMI output question
post #1 of 11
Hello everyone,
I have a PC in a conference room, 2 graphics cards one with HDMI and one with VGA or DVI output. HDMI is going into an 80" sharp LCD. The VGA is currently going into a projector in the ceiling. The 80" LCD is running at 1920x1080 and the projector only runs at max 1024x768. I am looking for a scaling box of some kind that will take the signal 1080 from the PC and scale that to the 1024x768 projector so it is not badly skewed.
Any ideas?
Jordan
post #2 of 11
Originally Posted by Barqs View Post
Hello everyone,
Any ideas?
Jordan
Might be more cost effective to replace the projector with one that is full HD.
post #3 of 11
Yeah, We had our local AV company come out and quote us 20k on the job due to the long throw lens. So we were investigating other options.
Thanks for your input!
Jordan
post #4 of 11
Doesn't the 80" hdtv have an internal scaler?
Run the computer at 1024x768 resolution and let the TV's scaler convert it to 1920x1080P.
post #5 of 11
Hmmm, got to be a better projector option. Move it in the process of relocating? The fact that you have a 4:3 projector and 16:9 TV is going to make any scaling a mess. What video card do you have - I thought I got an AMD card in a laptop to work duplicating a 4:3 image on a 16:10 screen with black side-bars. Play with those video driver options.
post #6 of 11
I will take a look on the Sharp 60" to see about internal scaling. I'm stuck with this projector sadly can't get approved for the 20k+ to replace it. I am running 2x amd 4350 graphics cards.
Jordan
post #7 of 11
Hello everyone,
Any ideas?
Jordan
You mentioned a 20k quote on a projector due to "Throw". I know when I looked for my outdoor theater projectors, I saw several 1080P projectors which could throw a very bright image @ 1080P to almost 30' away and were around $1000. Those can all handle decently long throws with 4000+ Lumens. No lens required.
BenQ SH910
Optoma TH1060P
If you needed lens shift, the BenQ SH940 was also bright and added lens shift for around $2500.
post #8 of 11
Hey Damelon,
The 20k would also be to run new cables (HDMI) in wall from the PC on the opposite side of the room, Along with replacing the powered projector screen in ceiling. We run a Crestron system in the room so a few of those components will need to be updated also!
If anyone has any hardware solutions I'm all ears!
Jordan
post #9 of 11
You don't need any expensive hardware to do this. All you need is windows 7. Windows 7 is perfectly capable of displaying different resolutions at the same time based on your device. Right click on your desktop and select properties. Click your tv/beamer and you can assign a resolution to it.
You were seriously thinking about spending 20k on this??
Edit: You want to clone the image to the tv/beamer? In that case you will have to set the amd/ati driver to 4:3 aspect ratio (black bars) for the tv.
Edited by sjaak1234 - 10/8/13 at 11:31pm
post #10 of 11
Hey Sjaak,
Yeah that is what we were trying to avoid the black bars. Still shocking this day in age you cannot run 2 video cards to two monitors cloning the same image. You would think modern hardware would have 100x more processing power then would be needed to scale everything.
Thanks for all of your suggestions everyone.
Jordan
post #11 of 11
Except you don't want to clone the image. You want the same image displayed the same way on different aspect ratios. Obviously this cannot work because the aspect ratio is different. Depending on whether you want to clone the tv or beamer this means image information needs to be cut or added.
The tv will always display more information because of it's higher resolution so what you are asking would never work even if the software supports it.
For example: If you make a power point presentation that makes full use of the tv's 16:9 aspect ratio, you can never fit the same information on the 4:3 beamer without cropping. So you will need to keep this in mind when making your presentation at which point you might as well design it for 4:3 and go with the black bars on the tv.
You just cannot have a native 16:9 image and 4:3 image display the exact same picture.
