AVS › AVS Forum › Audio › Speakers › Revel F208 or Klipsch RF-7II
post #1 of 166
I am building a Home Theater and i would like to hear an opinion from all the members that can help me decide.
I've heard Klipsch RF-7II and Revel F208, but with different amps.
The Revel seemed to be a much superior speaker, i don't know if the amp made the difference. I am tempted to go with Revel in Piano Black.
Since it's a living room i must put a speaker that is beautiful also.
post #2 of 166
I've heard both. I've owned the klipch rf-82 and revel m105. The win goes to the Revel, no contest. The Revel is about is good as they get.
post #3 of 166
Think no further.
post #4 of 166
The Kef R900 would be one of the only other speakers I would consider in comparison to the F208 and that would simply be a preference / room thing. Revel would be my choice based on the OP's selection options.
post #5 of 166
Absolutely. KEF R900 & Revel F208. They are a toss-up. Almost like twins. biggrin.gif
post #6 of 166
The R900 is a great recommendation. I'd still have to give the very slight nod to the Revel because of the wider dispersion.
post #7 of 166
I would prefer to buy the JBL LS80 in a second compared to Kef R Series. I like Kef, but for Home Theater is much better Revel or JBL Synthesis.
The JBL Synthesis LS Series are also speakers for me to consider...they have the "boom factor" extremelly important to make movies come alive. Or by the other hand i will go Revel.
Klipsch is a nice speaker, and here talking of the RF-7II, but not as refined as the ones i mentioned...
post #8 of 166
I am wondering if the LS Series connected to a Pre/Pro or High End Receiver if they perfom as well as being connected to JBL Pre/Pro...
I know that for the "Array" Series it makes difference....
post #9 of 166
Price wise are you comparing them as equivalent?
post #10 of 166
I hope not the revel retail for 5k. Almost 2k more than the rf-7ii.
post #11 of 166
Don't know much about either; but, do know that's not the top of the line Klipsch.
Is that the top Revel?
post #12 of 166
The F208 is the top of the mid line Revels, Performa3s. The Salon2s are the top of the Revel upper line, Ultima2s. I have heard the Studio2s, driver size close to the F208s, which were amazing. If the F208s are close to the Studio2s - and am told they are - they will be fabulous.
post #13 of 166
Thanks. I'm told you can buy five (5) RF-7II for $5K. FCR + 2 Surrounds will be Wonderful; if he has the room.
Don't know the street price of the Revels, though.
post #14 of 166
Even if with 5k i buy 5 RF-7's, i prefer 2 Revels F208. Klipsch finish is so, but so "cheap", when you look at them from a certain distance they look very good, with the gold woofers, but then they are made of "MDF", that's not even wood.
Besides Revel does not only has a good finish but it's sounds amazing, for CInema is spectacular. But i haven't decide, because JBL LS80 is not so "sweet" playing music, but it has more "kick" for Cinema. It's also cheaper than Revel, and much better finished than Klipsch.
post #15 of 166
OK, I'm sure you'll love them.
post #16 of 166
Sounds like you didn't need to start this thread then.
MDF is pretty standard now for speakers cut by CNC as it doesn't chip and has more uniform characteristics from most plywood. Are Revel speakers made from solid wood?
Perhaps rename the thread "Revel F208 or JBL LS80" then?
post #17 of 166
I'm sure I'm preaching to the choir, but you'll need lots of power for the Revel, being relatively inefficient; although I'm sure they all can benefit from more "horsepower".
post #18 of 166
Another Klipsch fan boy I see.smile.gifsmile.gif Just kidding. I recently sold my Klipsch KG2 and KG4 speakers. I have also owned RF7's.
I still have KG 5.2 and Revel F32. I know you are familiar with all the debate on Klipsch forum about power amps needed for RF 7's. Having owned them I agree. They need as much power as the Revels to properly perform.
The Revels do open up a little more at louder levels but so do the KG5.2's as their efficiency is low 90's.
Bottom line is the Revels will play as good as Klipsch with any given amp/AVR in my experiences.
post #19 of 166
Why, yes, yes I am; but, at this stage I personally wouldn't have either.
Doesn't mean the Revels won't be a pure joy for him.
I should've said the Revels will require more power to drive to reference level; but, I'm sure he plans P, for plenty, at any rate.
post #20 of 166
The Revel is a fine speaker but it is in a different class than the RF-7 for sure. It is the same price difference between the two as if we compare the Revel F208 to the Klipsch P-37F. Klipsch P-37F
post #21 of 166
And I wouldn't use any of them in an HT room, personally. Stereo in living room, for sure; very nice speakers. Am I wrong or is this thread more about living room stereo more than backroom HT?
post #22 of 166
OP mentioned HT in 1st post.
post #23 of 166
Originally Posted by jima4 View Post
The Kef R900 would be one of the only other speakers I would consider in comparison to the F208 and that would simply be a preferenceEoRNcT/room thing. Revel would be my choice based on the OP's selection options.
They look the same.
post #24 of 166
He mentions HT in a living room... and talks about a pair of speakers rather than 5.1.
post #25 of 166
Perhaps he'll clarify.
post #26 of 166
Speaking from experience the Revel F32 is as good as the RF7 for HT and superior for music. The Reference speakers have poor mids for music.
Have your tried both?
post #27 of 166
No, I just prefer bigger horns for HT for dynamics so wouldn't pick those for HT (you have introduced yet another model BTW; I wonder if an 86 dB sensitivity speaker can be as dynamics as big horns). Not that big horns aren't good for music; I can sip wine while I pinpoint the instruments in front of me like any other audiophile.
post #28 of 166
Dynamics are relative. Important things to consider are room size and preferred listening levels. If you have a large room and like to listen at reference levels or more, then you will probably want horn speakers. A horn speaker shouldn't be any more dynamic than a traditional cone and dome/ waveguide speaker given that both aren't driven to thermal compression, but that can be a big caveat depending on your situation.
post #29 of 166
Sorry guys i didn't clarified. So at the momment i have 2 options on the table, and Klipsch is not one of them:
JBL Synthesis:
- LS80 (Front) x 2
- LS Center
- LS60 (Back Surrounds) x 2
- SVS Subs Ultras x2
Revel:
-F208 (Fronts) x2
-C208 (Center)
-F206 (back) x2
-B112 (Sub) x2 or SVS Ultras x2
Prices of JBL are cheaper, and to be honnest i am tempted to go JBL, and the min reason is that is more adequated speaker for cinema, and looks good on the living room.
post #30 of 166
What percentage Music Vs. Cinema?
  Back to Forum: Speakers
