AVS › AVS Forum › Audio › Speakers › HSU Hybrid 3
HSU Hybrid 3
post #1 of 6
Anyone have any inputs on this package or any sort of comments? been thinking about getting this for a while, however, if their are any other options, I'm all open to hearing.
I'm not really sure what kind of receiver I will be getting yet... what would be a good one to power these?
I'm looking to spend $500 on receiver.
post #2 of 6
I have this set ,in the 5.2 version, although with the previous generation (the mk 3) subwoofers. I'm very happy biggrin.gif with them. I'm probably biased, but I've really not seen or heard any negative reviews, at least from people who have actually heard them. wink.gif
this is IMO, and of course, YMMV.
Joseph.
side note, have you looked through the "I'll demo my speakers..." thread ? There are a couple of us with HSU set-ups listed there.
post #3 of 6
Joseph.
Thanks for the info, I have not done that yet, I'll start taking a look at that.
post #4 of 6
HSU Hybrid 3 is a very good setup. There are other speaker/sub choices that are equivalent in class for the money, but I don't see how you could do better smile.gif
post #5 of 6
Just get any AVR thats 5.1 capable with Audessey. (this is important because you need to EQ your sub). Horn loaded speakers are generally efficient so 80 - 100 wpc would be more than enough.
Edited by NAIM101 - 10/1/13 at 12:43am
post #6 of 6
The HSU are horn loaded, but its not horns that make speakers efficient. It's the compression driver mated to the horn. HSU's have a dome tweeter mated to the horn. Fairly efficient, but not quite as good as a good compression driver.
To the OP, hard to get better for the price. It's a good set up.
  Back to Forum: Speakers
