AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Help on Wireless Set up for new Denon AVR-4520CI
post #1 of 6
I just picked up a new receiver...  thought it was wireless, but it is not.  Does anyone know a good wireless adapter or dongle that is current to buy.  My router is way across the house from the receiver so wired is not an option.  Thanks.
post #2 of 6
You can buy a 4 port wireless bridge. That way you can have 4 ports at your entertainment center.
post #3 of 6
Can you provide a link to one that would work.  I"m a bit of a rookie with AVRs.  Are they pretty easy to set up?
post #4 of 6
What kind of router do you have? Wireless-N I assume? If so, something like:
http://www.amazon.com/gp/offer-listing/B004FMI3DA/ref=sr_1_1_olp?ie=UTF8&qid=1380521075&sr=8-1&keywords=4+port+wireless+n+bridge&condition=new
would work for $42. They are easy to set up. Just plug it into your router (wired) and browse http to the setup page and point it to your wireless network and enter the password. Done. Take it to the TV area.
post #5 of 6
One more question. I have an amp upstairs that controls all speakers on that floor. There is one wire containing 4 wires that run into the amp. Where do I plug those wires in on the receiver. It is an A/B amp that gives options to turn on/off certain rooms. But I only see zones on the new receiver.
post #6 of 6
