AVS › AVS Forum › HDTV › HDTV Technical › no audio
no audio
post #1 of 2
I have a Dell w3201c. The picture is fine but the audio is gone. If I plug it into a receiver or a sound bar through the audio out I get sound. Any idea what the problem may be?
post #2 of 2
This isn't the section for television problems. You'll want to post in the Display area for LCD sets. Also use a far more descriptive title. Thanks.
  Back to Forum: HDTV Technical
This thread is locked
