Recommend corner TV stand
post #1 of 2
I need a corner TV stand which has black as its main color (metal/glass parts OK). Something simple, elegant, and not obviously junky. Stand will be placed in a room corner and will ideally support a 46" thin plasma TV and a blu-ray dvd player.
Do you have an suggestions?
post #2 of 2
What's your budget? I see ones online for as little as $250; nicer ones up to the $1000-$2000 range.
