AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official PSA Triax Thread
post #1 of 3312
I don't see a Triax in my future but based on what you guys have been posting, a Triax thread needs to be started. Good luck with all your Triax dreams. biggrin.gif
"Triax"
"Measurements"
New Triax driver images.
Edited by BeeMan458 - 10/9/13 at 7:07am
Gear mentioned in this thread:
post #2 of 3312
Working with you, I'm currently trying to spiff up the thread a bit with PSA based links.
Spelling typo of "Official" corrected and as you suggested, "PSA" was added. If there are any other suggestions, I'm happy to add them to the original thread.
And when available, new driver pics to be added. If I shouldn't have started the thread, let me know and I'll remove as much of the thread as possible, including the title and someone else can start the thread.
Measurement tab link corrected. Not so sure about the comma comment but in the spirit of cooperation, the change was made. The last thing anybody wants, is for me to edit their papers.
Edited by BeeMan458 - 9/30/13 at 4:07pm
post #3 of 3312
post #4 of 3312
Also, there shouldn't be a comma in the thread title, the Triax is made by PSA
You can also do http://www.powersoundaudio.com/products/triax#tabs-3 so that it pulls up the Measurements tab when you click on the link
post #5 of 3312
I could be wrong but I believe those measurements are from the original drivers.
post #6 of 3312
I don't believe the website has been updated yet.
post #7 of 3312
I believe so as well but until Tom/Jim update them on the site that is all we have.
Plus I think Tom mentioned that there isn't a huge difference either way but I also know that a lot of guys on here like to argue over the dumbest specifications like it makes a difference that you can hear wink.gif
post #8 of 3312
Tom mentioned to me that the improvements are "fairly subtle" (his words).
post #9 of 3312
post #10 of 3312
As new information becomes available, as necessary, I'll be sure to update links.
post #11 of 3312
*twitches*
post #12 of 3312
Just out of curiosity, how does PSA recommend you place the Triax? In a corner? against a wall with one driver parallel? Drivers at an angle to the wall?
post #13 of 3312
Just like any sub, you place it accordingly to get the best room response...there is no set standard.
post #14 of 3312
It shouldmhave a 2 to 2.5 db gain, im unsure about what freq they are but that isnallot if you ask me.
post #15 of 3312
The gains and differences have already been covered. Tom said with the new drivers the Triax Averaged 125.39db 20-63hz cea2010 2m rms. With the Old drivers the 20-63hz average was around 122db. The new drivers gained 3.39db.
http://www.avsforum.com/t/1372020/official-power-sound-audio-thread/6060#post_23780836
He probably mentioned it being very subtle until all the testing was done...in his last post regarding the numbers he even said,
"I don't like the idea of the weight and cost increasing but I can't argue against the performance of the new drivers"
That being said the new drivers improved performance significantly, but its not like the old drivers were lacking. I doubt you will notice the difference in most rooms, especially if you do not listen above reference.
Edited by basshead81 - 10/3/13 at 8:46am
post #16 of 3312
I don't like average CEA numbers like that. This could be a 50 hz monster and low at 20 hz. The individual or long term max numbers mean much more to me. Anyways this sub seems to be very nice either way!
post #17 of 3312
20-31hz 119db 40-63hz 130db cea2010 2m rms.
post #18 of 3312
That is a little better. I want to know what this can do at 10 Hz!
post #19 of 3312
But it's not like any other sub. Down firing always fire to the floor, front firing always fire into the room (I know some recommend firing into a wall, but who does that?). There's only one possible configuration with 99% of subs. I can't believe there's no guidance on this, particularly since it weighs close to 200 lbs. Not easy to move.
post #20 of 3312
Isn't that going depend on room gain and the effects of corner loading? Factoring in these two points, the graph says it totally kicks butt at 10Hz? In my opinion, without factoring in room gain and corner loading, one is not getting the full picture.
post #21 of 3312
All subs get the same effect by the room.
post #22 of 3312
Absolutely. Sorry. I'm seeing it as not all rooms are the same, opposed to all subwoofers are treated equally within the confines of a space; sealed vs ported sub vs large open to other spaces vs a sealed room. It's just a thought as opposed to an argument.
I would expect a corner loaded Triax, within the confines of a space, to have kick butt room gain that will carry this sub, properly integrated into a room's acoustics (multiple subs expectedly will be needed for room smoothing), down to 10 Hz or lower.
Regarding my comment, in understanding, what am I missing?
Edited by BeeMan458 - 10/3/13 at 1:55pm
post #23 of 3312
+1
Where did you get those numbers? Is that from the "guestimate" someone posted earlier when I asked about the new 20-31.5 hz and 40-63hz numbers? I haven't seen these numbers from PSA and the website hasn't been updated yet.
Josh Ricci did a test that showed that orientation didn't make a difference with dual apposed and down firing designs. I would expect the same behavior from the Triax. Front firing designs did have FR changes depending on orientation.
Tom's only mention to me about orientation was to make sure to leave some space between the driver and the wall (I believe he said at least 1.5").
post #24 of 3312
+1
That was my guestimate....this stuff is not brain surgery. How hard is it to add calculate averages and do simple math? tongue.gif
post #25 of 3312
I realize we're not talking about big differences here, but taking the average gain and applying it to the ULB and LB numbers doesn't necessarily work depending on at what frequecies the new driver outperforms the old.
post #26 of 3312
Yes, I want to see an ID sub rule the commercial market on D-B! Right now the Sub2 reigns supreme for sealed subs. The DIY and kits rule otherwise. I guess you can say the DTS-10 can be bought built so that can be the standard for commercial products except at 10hz. That kit sold for $995! The Triax should do very well at 10hz no matter where it is measured due to 3 high excursion 15's. Are they still 30 mm of x-max? I just received my 8 30 mm of x-max 18's from Fi for the IB I am building. I had 12 inch 28mm drivers so I can understand what higher excursion means, more linear down low!
post #27 of 3312
Many people do face their subwoofers into the wall. In theory this will load the driver and increase driver efficiency. It may not look as pretty, lol. Since subwoofer are not direct radiators, orientation is not a primary concern.
post #28 of 3312
When you are coming up with the average numbers, are you converting the dB to pascals before averaging? That's too much work for a lazy guy like me.
post #29 of 3312
How does it not?
Tom said the new drivers averaged 125.39db 20-63hz.
Take the old numbers and add them together and divide by 2. 116.4 + 127.5= 243.9/2 = 121.95db 20-63hz.
The point is the new drivers are showing about a 3-3.5db increase.
I agree its not an exact measurement but its enough to get close. The folks that pre ordered a Triax are getting a nice increase in performance with no extra cost.
post #30 of 3312
Tell em Basshead
