AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official PSA Triax Thread
Official PSA Triax Thread - Page 59
post #1741 of 3312
Originally Posted by Blackmambakila View Post
Now it doesnt do it if i pause the movie and shut off the light.
Gear mentioned in this thread:
post #1742 of 3312
The triax makes a poping sound when i turn the lights off.
post #1743 of 3312
Doesn't do what?
post #1744 of 3312
Make the poping sound.
post #1745 of 3312
The only time I have ever had a popping sound... Was when I unplug the power cord and plug it in.Are you sure your power cord is secured? Are you using a cheater plug?
post #1746 of 3312
post #1747 of 3312
Yes its secure, i tried a cheater plug and it made a loud hum that shook the room.
post #1748 of 3312
Are you sure your house was not built over Indian burial grounds?
post #1749 of 3312
It might be the circuit break that is causing the popping sound. Using a power console for everything may eliminated the ground loop problem. It worked in my case. Glad you got your sub josh jp!!!
post #1750 of 3312
Umm im unsure.
post #1751 of 3312
Umm im unsure.
Send Tom an email... He might be there still.
post #1752 of 3312
Originally Posted by Reefdvr27 View Post
I would go with Monster University first. I read that baby gets down to 1hz eek.gif
I would get back out to the store and get Olympus has fallen and Oblivion and also Unstoppable if you can find it.
How's this?
Definitely a better selection. Cloverfield and OHF will give the Triax a workout. Of the previous assortment, only WWZ really does anything to make the Triax shine, all the rest of them (including MU) would sound almost as good with far less capable subs. Don't forget WOTW and TIH.
Max
post #1753 of 3312
TY i did and called, havent heard back yet.GRR
post #1754 of 3312
Do you have a power center or surge protector?
post #1755 of 3312
Max
Thanks man! I've gotten so many movies lately, I'm more than ready for this sub! If my house breaks I'll be happy!
post #1756 of 3312
Umm im unsure.
Can you run an extension cord from another room to the Triax and see if it helps?
post #1757 of 3312
Try different outlets and see if this could eliminate the possibilities.
post #1758 of 3312
I wonder if you have a bad light switch... Have you seen it happen when you turn on other lights? Another option might be to try a power conditioner.
post #1759 of 3312
11/15/2013 8:49:00 AM Departed CHICAGO, IL in route to SACRAMENTO, CA
11/14/2013 5:45:00 AM Arrived at CHICAGO, IL
post #1760 of 3312
Mine is sitting in Chicago now. Mine is only going about a hundred miles further than yours.
No matter what we both should be enjoying ours sometime next week. smile.gif
post #1761 of 3312
Where in NorCal are you? Mine still has to travel another 165+ miles down to Fresno after it hits Sacramento.
post #1762 of 3312
PM'd
Mine is going to Benicia, then out for delivery.
post #1763 of 3312
Yea a Panamax, it didnt help.
post #1764 of 3312
No it would be hard to.
post #1765 of 3312
Try turning on different light switches on the same circuit. It might be a switch with bad contacts.
post #1766 of 3312
M
man that sucks bad, grrrrr. But you will get it next week.
post #1767 of 3312
TY, i have no idea whats on what circuit.
post #1768 of 3312
I would try all lights in the room or adjoining rooms. If it does it with only one light it is a good chance it is the light switch IMO. I am sure Tom will get back to you soon in anyway.
post #1769 of 3312
I've got a 4runner, I'll provide the moving straps, all you have to do is provide the Triax......seems like a good deal to me biggrin.gifwink.gif
Edited by Rowan611 - 11/15/13 at 8:29pm
post #1770 of 3312
It's pretty simple; with digital signals, the cable is either fully passing all the 1's and 0's properly, or it isn't. There is no such thing as 'richer' or 'more vivid' colors or 'tighter bass' due to 'better' HDMI cables.
You either get the digital signal properly, or you don't. First indicators of a sub par HDMI cable is usually video sparklies and other anomalies (neon posterization) etc., to severe blocking and loss of picture. The folks claiming richer colors and deeper blacks are full of it and don't understand the differences between digital and analog signals.
Max
Thanks...pretty simple.
