AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official PSA Triax Thread
Official PSA Triax Thread - Page 4
post #91 of 3312
Originally Posted by Saturn94 View Post
I just ordered this to help get my Triax into place and move when needed. Anyone use this before?
http://www.amazon.com/EZ-Moves-Furniture-Moving-System/dp/B005FGAP7W/ref=sr_1_2?ie=UTF8&qid=1381368328&sr=8-2&keywords=Furniture+lift
You don't have any buddies willing to give you a hand moving it?
Gear mentioned in this thread:
post #92 of 3312
I have one volunteer.
post #93 of 3312
We have that same kit. My wife bought it. We actually use it for our coffee table. We bought a new leather sofa and it has two recliners, so we put those sliders under the legs of the coffee table to move the table back and forth when we recline. They work well.
post #94 of 3312
Do you think the lifter will be adequate to lift the Triax enough to get the sliders under it?
post #95 of 3312
(oh wait, you mean the leaver thingy)
One hand turned backwards should be able to lift the subwoofer sufficient to get sliders under the legs. A simple block of wood and a two foot piece of 1x2 would tip the subwoofer up as it wouldn't take but twenty-five to fifty pounds of downward force to tip the subwoofer up.
Edited by BeeMan458 - 10/10/13 at 8:10am
post #96 of 3312
I bought a set of these for my pair of XS30's. It came in extremely handy when I was running sweeps and finding placement for them. I have the outlaw wireless kit, along with a good extension cord, placement and setup was very easy with the sliders. They will work.
post #97 of 3312
I don't think you will need the lifter to lift it. Honestly, I never used the lifter, just the sliders.
post #98 of 3312
We use the furniture sliders frequently on 650-700lb pool tables, so they should work fine for a 230lb sub.
post #99 of 3312
Lifter is overkill, agreed. I do not have this exact "kit".
post #100 of 3312
Looks like the Triax 2m rms data was updated.
20-31hz 117.8db
40-63hz 128.9db
20-63hz 123.35db
The 20-63hz average is down about 2db from Tom's initial post on the new drivers. I assume thats why he didnt update the info right away. Either way still looks to be about a 1.5db gain across the board...more is better smile.gif
post #101 of 3312
20-31hz 117.8db
40-63hz 128.9db
20-63hz 123.35db
post #102 of 3312
Where did you locate the new 2m information? So as to update the first post, I looked all over the PSA website and was not able to find your information. confused.gif
post #103 of 3312
20-31hz 117.8db
40-63hz 128.9db
20-63hz 123.35db
Holy cow, if that's the case the Triax will officially knock the Paradigm Sub2 off as the top sealed commercial sub as soon a Josh Ricci tests one! (hopefully he tests one biggrin.gif)
post #104 of 3312
20-31hz 117.8db
40-63hz 128.9db
20-63hz 123.35db
That seems to fall more in line with Tom's description of improvements being "subtle".
post #105 of 3312
Lets not forget all about all of the doubters and haters (aka shadyJ...lol) that will come out and say "I'll believe it when I see some third party measurements" rolleyes.gif
Personally I think Tom and Jim have no reason to lie because they know that eventually someone like Josh will test it and the truth will come out anyways.
I 110% believe that under what ever 2m ground plane testing conditions they achieved these numbers under were the numbers the Triax actually hit with the new drivers.
post #106 of 3312
I agree but when he initially posted 125.35db 20-63hz, that is alot more then subtle compared to the 121.9db average of the original drivers. Thats all I was basing my info on...my apologies for thinking ahead. I was hyped up for you pre order folks that waited this whole time. It is still a solid upgrade none the less. smile.gif
post #107 of 3312
For alot less money too! Thats getting up there with the folded horn subs...better add one to them XS30's lol.
post #108 of 3312
Those are incredible numbers, look at those even compared to vented! No there is no way Tom fudged on the numbers, sounds like maybe you remember a post by Bill F regarding something like that. NOPE! not gonna happen.
post #109 of 3312
Old Triax Drivers: 2m rms
Ultra-low bass (20-31.5 Hz): 116.4dB
Low bass (40-63Hz): 127.1dB
New Triax Drivers: 2m rms
Ultra-low bass (20-31.5 Hz): 117.8dB
Low bass (40-63Hz): 128.9dB
post #110 of 3312
post #111 of 3312
20-31hz 117.8db
40-63hz 128.9db
20-63hz 123.35db
117.8dB at 20-31Hz (2m) requires 3 x 800cm^2 Sd (15") drivers to each move 40mm one way (cleanly, of course). So we're in the ballpark with what physics says is possible, but it's probably a bit overstated comparable to Data-Bass numbers (just like the XV-15 was).
I'd knock that number down ~2dB, expecting somewhere around 30mm of clean throw one way.
post #112 of 3312
20-31hz 117.8db
40-63hz 128.9db
20-63hz 123.35db
If you don't convert to pascal (per CEA) before doing all of this you will end up with a completely different data set. Our current data set averages to about 125dB from 20-63hz which is within 0.4(?) of my last posting.
Tom V.
Power Sound Audio
post #113 of 3312
Remember, the 117.8dB is an average of 20,25,31hz..
There's always going to be 0.5dB here or a dB there between test sessions.
Also, if you consider the differences in enclosure orientation for the XV15 the data is within 0.5 - 0.75dB which is really a tight tolerance. Anyone who has experience measuring outside would agree.
Tom Vodhanel
post #114 of 3312
Got the email I've been waiting for, my first Triax is shipping this afternoon, really have anticipated this for a long time. I can't wait to hear the first reviewer.
post #115 of 3312
post #116 of 3312
I am more curious to hear what the owners think these days. Too many benchmark subs out there without 3rd party testing. I don't think it is in Tom's interest to worry about this.
post #117 of 3312
I think we'll get through most of the pre-orders (120 volt) for May and June today. 208-240v orders will take up much of next week. I'm hoping all orders through end of July will be taken care of in this production run(by mid next week). Second production run is scheduled in about 10-12 days. That will be a much larger "run" and should fulfill all current orders.
As much as we would love it----we just can't assemble and test 25 Triax a day. I am estimating 8-12 a day when we can completely focus on them(like today).
If you ordered in May or June you should see tracking info in your inbox late this afternoon. A few toward the end of June may slide until early next week though. We'll do our best!
Tom V.
Power Sound Audio
post #118 of 3312
I am getting excited for those who ordered these beasts. Seem to be a great value.
post #119 of 3312
So if im part of the first batch, i wonder where that puts me as far as a time frame?
post #120 of 3312
When did you order the Triax? I ordered my first in August so it looks like I won't be seeing a shipping notice until mid-late next week.
