AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Commercial LED-Lit LCDs
post #1 of 4
This might be an unusual question, but I need some recommendations on commercial LCDs. I would like them to be LED-lit, and the slimmer the bezel, the better. They do need to support 4:4:4 chroma subsampling. I'm not very familiar with commercial displays anymore. There used to be many plasmas in that space, but for this project burn-in is a concern.
I appreciate any help you guys can give me.
post #2 of 4
Not sure about the specific specs you requested, but NEC and Marshall make some very good commercial displays. I would check them out first.
post #3 of 4
Thanks, I'll check out Marshall. I'm looking at the NEC X401S right now as well. It's tough finding reviews on these displays!
post #4 of 4
I should have said, as far as I know, Marshall mainly makes broadcast displays for TV trucks and studios. Most of them will only have HDSDI inputs. Although I do have one thats a couple years old that does also have composite inputs.
