AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-103D (Darbee Edition) Owner's Thread
Official OPPO BDP-103D (Darbee Edition) Owner's Thread - Page 86
post #2551 of 3665
Originally Posted by wmcclain View Post
People say Darbee does not affect calibration, but I would ask the calibrator. Give him all the specifics and see what he says. Does he need all the final gear in place or not?
-Bill
When I had my Zt60 calibrated the calibrator said that the darbee has no effect on the calibration for grayscale,gamma,WB,color etc. The only time you will see effects on the PQ is when you boost the darbee past 40% (slight artifacts possible), but then again it depends on the display if you see any artifacts. The calibrator and I played around with all the darbee settings to see if there were any affects on the test patterns and there was not any up to about 40%, above that very, very slight effect on some of the vertical white line test pattern during sharpness tests. All my 103D pictures settings are at "0".
post #2552 of 3665
Well boys and girls will be connecting my 103D today... kill some pre-super time. Long time Oppo guy (going back to the 971) looking forward to the new player hooking it up to my ZT60 smile.gif
And also have to add much appreciation to this more "Proper Thread" with the FAQ etc in post 1. Kudos to Neuromancer and gang.
Sure I will have questions.
Edited by bvader - 2/2/14 at 9:56am
post #2553 of 3665
Many thanks for the replies. The Darbee processor outputs from HDMI out 1 and the blu-ray outputs from HDMI out 2?
post #2554 of 3665
Question......just wondering. ...can the 103d darbee work on feed from bright house cable box????
Can it have the same effect on feeds from cable...
How do u connect thru av player
Edited by amercnchopz34 - 2/2/14 at 12:25pm
post #2555 of 3665
Yes.
What? Say again?
-Bill
post #2556 of 3665
Yes.
What? Say again?
-Bill
HDMI Input 1 on the back is processed by Darbee and outputs thru HDMI output 1? Therefore, my cable box would be connected to HDMI input 1 and output HDMI 1? So I'm thinking that the blu-ray would not need any processing and would be output thru HDMI 2? Or can both cable box and blu-ray be processed by Darbee and be output thru HDMI 1 since they cannot run simultaneously?
post #2557 of 3665
Darbee is available (and optional) on HDMI1 output. It doesn't matter what the video source is: Blu-ray, HDMI input or other.
HDMI1 input is not linked to HDMI1 output, or HDMI2 input linked to HDMI2 output. Any input is available on any output.
-Bill
post #2558 of 3665
-Bill
We know that the blu-ray also benifits from the Darbee - A question but why aren't you using the player in the Oppo?
post #2559 of 3665
Does anyone here have the HEX code for the Darbee button on the 103-D?
post #2560 of 3665
YES - same effect on cable - Run cable box into HDMI In - Run HDMI out from HDMI OUT1 (on rear panel) to AVR
post #2561 of 3665
-Bill
So, do I have the ability to switch Darbee processing between blu-ray and input 1?
post #2562 of 3665
http://www.oppodigital.com/blu-ray-bdp-103/blu-ray-BDP-103-Support.aspx?prodID=BDP103D
post #2563 of 3665
You switch it on and off for HDMI1 output. It has nothing to do with any input.
-Bill
post #2564 of 3665
-Bill
Many thanks Bill!
post #2565 of 3665
I just looked and it is not listed on the excel sheet.
Here it is:
command set #1:
0000 006C 0022 0002 015A 00AD 0015 0040 0015 0016 0015 0015 0016 0040 0015 0015 0016 0015 0015 0040 0016 0015 0015 0016 0015 0040 0015 0040 0016 0015 0015 0040 0016 0040 0015 0015 0016 0040 0015 0015 0016 0040 0015 0040 0015 0040 0016 0015 0015 0016 0015 0040 0015 0016 0015 0040 0015 0016 0015 0015 0016 0015 0015 0040 0016 0040 0015 0015 0016 0040 0015 0600 015A 0055 0015 0E62
post #2566 of 3665
Thank you
Got 103d today.....not familiar with set up...tried hdmi on cable box to hdmi in on oppo hdmi 1 out on oppo to reciever....what port do I put in on ..hdmi sat/cable....or blu ray...Then the one out on avr to zt60 right
How do I watch cable and switch to blu ray....can I do both??
Edited by amercnchopz34 - 2/11/14 at 2:40pm
post #2567 of 3665
thanks
post #2568 of 3665
This costs $599 in the states, $700 in Hong Kong and $1300 here in sweden, ouch that's europe for you! frown.gif
Got my 93 from UK cheaper and is going to travel to HK soon so maybe I try to buy one there and smuggle home wink.gif
post #2569 of 3665
I want to use the 103D to process all the AVRs video out to the TV
I am having trouble getting the Bell Sat Box (AR 9242) to connect through the 103D to the AVR (Yam RX-Z11 set on HDMI pass through) then to the TV
All inputs including 103D connecting through AVR HDMI out to TV (Samsung PN60F8500) input HDMI 1 - works fine
103D by itself to TV HDMI 1 works fine (no sound as TV speakers muted)
The Sat Box to 103D input then to 103D HDMI 1 output - no go at all
At 1 point (hooking up) whatever - I got a screen asking for a ARC connection - which always fails.
I do not want or need the ARC from TV to AVR - nor 3D
Any suggestions?
Is there something in the 103D I have to set up or enable for the INPUT HDMI ??
Edited by Dougofthenorth - 2/3/14 at 12:15pm
post #2570 of 3665
Any suggestions?
Have you tried dual output (HDMI 1 video to display and HDMI 2 audio to the AVR? Your current problem doesn't make sense to me (all you should have to do is "select" HDMI 1 input rear); but the dual output may be a work around.
post #2571 of 3665
Any suggestions?
The latest public 103D beta fixed my HDMI connection problems. My TV would blank screen as soon as I attached the AVR to HDMI IN on the 103D.
Maybe worth a try.
post #2572 of 3665
Any suggestions?
take advantage of the best tech support around - call OPPO
post #2573 of 3665
Maybe worth a try.
I will do the FW update & see if it works with only 1 HDMI out if no then I'll try 2 outs - but where would HDMI 2 out go to as AVR selects only 1 HDMI in as does TV ??
Do these software/hardware geeks even own any decent PCs or HT gear or do their lives totally revolve around only iphones & smartphones & handheld consoles, maybe only D&D
Seriously, 20 years on forums for PCs & HT - only ever saw a small handful of these dudes on them...
Edited by Dougofthenorth - 2/3/14 at 2:32pm
post #2574 of 3665
Doug,
/edit: reading your initial post, I may have misunderstood your question, sorry. rlb is right querying what it is you are trying to do.
Split A/V is exactly that - HDMI 1 goes to your TV for picture and HDMI 2 goes to the AVR and does the HDMI audio ONLY.
Edited by pieandchips - 2/3/14 at 2:13pm
post #2575 of 3665
If I understand the question, HDMI 2 (audio) becomes your one and only HDMI to AVR for TV; because the HDMI 1 (video) is going directly to the TV. You could just run HDMI 2 to the same AVR HDMI input currently used for HDMI 1 and HDMI 1 could run to the same TV HDMI input currently used by the AVR HDMI output.
If you do the cable change, you must reflect it in the dual output section of the 103D setup. I use this for the OPPO 103D; but run all my other components through my pre processor.
post #2576 of 3665
Doug,
Will keep that in mind after FW update...
post #2577 of 3665
I use split a/v, with hdmi2 going to the avr and hdmi 1 to my projector directly.
Now when the projector is off the oppo will still send video out on HDMI2 so I can still use it on my tv, granted I don't get the darbee effect on the tv this way.
And since this didn't negate the minor HDMI sync issue in my avr i might as well just connect HDMI 1 to my avr, or try the analog outputs...
post #2578 of 3665
Does the 103D come with a wireless dogle?
Edited by mbroadus - 2/3/14 at 4:02pm
post #2579 of 3665
As shown on OPPO's page, yes: http://www.oppodigital.com/blu-ray-bdp-103/blu-ray-BDP-103D-Features.aspx
-Bill
post #2580 of 3665
Yes.
I'm currently using mine, purely because I'm too lazy to run the cable :P
