AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung 6300 LED Smart TV
post #1 of 11
My daughter bought this TV and it's advertised as builtin WIFI. We haven't opened the box yet because I see on the Samsung site a LinkStick is required for Wifi use.
What I don't know is - is that part in the box or not needed at all?
Nobody at the store knows the answer.
post #2 of 11
The Samsung 6300 series sold in America have built-in WiFi, so the adapter is not necessary.
post #3 of 11
Congratulations you have one of the best TVs out there. I have enjoyed it for over two weeks now, the picture is amazing. I did however calibrate my TV, by myself.
post #4 of 11
Wrench what panel did you get? The easiest way to see is look for the version number on the sticker on the side of the box or back of the TV. In the USA we have panel versions like TSO1 and TUO2.
Edited by snorge - 10/2/13 at 6:25pm
post #5 of 11
Originally Posted by snorge View Post
What panel did you get? The easiest way to see is look for the version number on the sticker on the side of the box or back of the TV.
I don't know if this was addressed to me or not. I will answer for myself. My tv was made the first week of September, I received it the second week. So everything is up to date. The panel is a Samsung. I do know all of the panel versions and specs. There were two versions of the 6300.
post #6 of 11
I was actually asking the the topic creator but I appreciate your input as well.
Edited by snorge - 10/2/13 at 6:24pm
post #7 of 11
Yes I was asking you. What exact model is your 6300? In the USA we have panel versions like TSO1 and TUO2.
I love reading about panels, every company has different specs for it's panels but all panels for a particular company must perform to it's specs. It makes no difference if the company is LG, Sony Samsung etc. You left out HS01 as a Samsung panel. Don't leave it out for it is Samsung. There are other designations that are also Samsung panels. I contacted Samsung through their chat with their experts. The HSO1 is a Samsung made panel, as are the TSO1 and TU02.
Edited by HDPERSON - 10/2/13 at 5:02pm
post #8 of 11
Oops lol. I thought you were the one who started the topic. I was replying on my phone and didn't scroll up all the way but thanks for your answer.
My mystery with panels began years ago when I bought a Samsung lcd computer monitor and received a really poor looking one with a Chi Mei panel. When I exchanged it for one with a Samsung panel I was blown away by the difference in quality. Maybe things have changed and the panels they use in their tvs are more or less the same regardless of manufacturer.
post #9 of 11
I wasn't so lucky - my UN55F6350 crapped out after 3 days! It's just as well because off-angle viewing was the worst I've ever seen - noticeable degradation in contrast and color at any angle greater than 15-20 degrees from center. Very disappointing as the ones I saw in three different locations had acceptable PQ at up to 20-30 degrees off center. FWIW, the one I purchased had a Samsung panel (Version: TH01), which is supposed to be the best.
I briefly thought about getting a replacement but decided to return it and move on. Best of luck with yours...
post #10 of 11
Sorry to hear about it. Bad lemons do happen, give it another try.
post #11 of 11
You probably just had really bad luck but also keep in mind the only way to know for sure it was a Samsung panel was to check the service menu as well.
