AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung Smart TV reset?
post #1 of 3
On the 2013 Samsung Smart Tvs is resetting through the service menu the only true way to wipe everything to the new just unboxed state? I know there is a master reset inside the onscreen menu system but it says it keeps your network info.
post #2 of 3
See if this is different than what you found in the menu.
http://www.samsung.com/us/support/howtoguide/N0000058/12117/142707
post #3 of 3
Yes that is what I saw in the onscreen menu. I wrote my post from work so couldn't remember the exact section it was under. So what is the difference between that an the service menu reset?
