AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Where to install Darbee
post #1 of 2
Hello,
My set up is pictured below - where would you install the Darbee? I'm more concerned with it enhancing my projector, so my best guess is to install it a few feet before the projector itself.
Other opinions?
post #2 of 2
I had trouble getting the Darblet to work reliably at the "far" (projector) end of a 35' HDMI cable - which has an Integra pre/pro at the other end (which are not known for their output drive strength). Placing it at the "close" end, on the output of the pre/pro, and it works perfectly.
I'd suggest trying first on the output of your Bose AVR - no reason NOT to have it enhance the picture on the TV as well as the projector... I think that location is the most likely to succeed, too...
Jeff
  Back to Forum: Home A/V Distribution
