AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Sufficient heft of 5.1 system?
post #1 of 2
Mounting TV and installing 5.1 system in "new to me" house. The room is 11.5 x 22 ft.
The following have been proposed by an installer for my project. Bear in mind that I will be using a Denon AVR-1910 as the source. And he will be mounting, running wires and cables and installing a Furman power conditioner/ protector and a Tripp Lite surge protector.
http://www.pinnaclespeakers.com/S-FIT_SOUNDBAR.html $399
http://www.pinnaclespeakers.com/subcompact8.html $349
http://www.definitivetech.com/products/promonitor-800 $250 pair
For this price range what are your thoughts?
Will this give enough oomph? How will it handle playing music? Honorably?
What is the use for Cat6 wire?
post #2 of 2
Depends on how badly you want aesthetics/footprint over performance for $. That's a very small sub for a large room (and it's overpriced). The specs on the soundbar aren't very impressive; there's only so much sound you can get from 3 inch drivers....even the surround speakers appear to be more capable.
You going to have bare floors as it appears? That won't help.
Why do you want a power conditioner? Might want to read this thread http://www.avsforum.com/t/1258060/are-power-conditioners-worth-it.
