AVS › AVS Forum › Video Components › Home Theater Computers › Sorting Out Blu Ray Playback
post #1 of 11
I just built a new HTPC and I am trying to resolve the issues I am having with Blu Ray playback on the unit (both from DISC and ISO).
Here is the system setup:
MSI FM2-A75IA-E53 MB
AMD A6-5400K GPU
Happuage WinTV-HVR-2250 Pcie TV Card (for OTA recording)
Windows 7 Home Premium 64 bit.
Windows Media Center
ArcSoft TotalMedia Theatre 6.0.1.123
AnyDVD HD 7.8.5.0
And, here is the test I ran today to check out Blu Ray playback on the system:
Original BR Disc:
WMC+TMT6=YES
TMT6 Standalone=YES
Backup of Original BR Disc:
WMC+TMT6=NO
TMT6 Standalone=YES
ISO File of BR Disc:
WMC+TMT6=NO
TMT6 Standalone=YES
So, original BR disc plays fine in WMC with TMT6 plugin and TMT6 standalone from the desktop.
But, a backup of the original disc (BD Rebuilder compressed) won't play on WMC with TMT6 plugin, but DOES play from TMT6 standalone from the desktop.
It is the same for .ISO file playback, plays fine on TMT6 standalone, but fails with WMC plus TMT6 plugin.
Should I just uninstall/reinstall TMT6 or is there something else going on here?
post #2 of 11
I don't think a rip/backup will play without circumventing encryption even with licensed players. I could be wrong though. You could try the AnyDVD HD trial to see if that resolves your issue.
post #3 of 11
Test was run with AnyDVD HD installed and operating.
post #4 of 11
Are you getting any error messages when playing the backup/ISO back with WMC + TMT6 plugin? or does simply nothing happen.
Is the ISO definitely being mounted to allow playback when using WMC/TMT? You can open My Computer and check if its mounted when TMT plugin is trying to play.
Edit - you could try running the TMT plugin outside of WMC (run umceplayer6.exe from Arcsoft install location) and see if it works.
Edited by acejh1987 - 10/2/13 at 11:57am
post #5 of 11
I will try the plugin outside of WMC, a good idea.
The ISO mounts correctly, and the TMT6 plugin initializes, but then drops back into WMC without playback, leaving the ISO still mounted in VCD. Could it be an issue with the Mount program? Several times WMC has declared the Mount program invalid, and I have been forced to uninstall/reinstall it to get back to mounting ISO's in WMC.
Tried both ripped disc and ISO with the umceplayer6.exe application. Both failed. ISO manually mounted via VCD was still mounted after program fail. It appears the plugin may be the issue. Should I try a reinstall?
Edited by jsauser11 - 10/2/13 at 12:19pm
post #6 of 11
You could try reinstalling, I doubt it will make a difference but it might.
When you maually launch the plugin does it attempt to play the mounted file or does the plugin just close itself?
post #7 of 11
Tried reinstall, no luck.
Plugin does attempt to launch (does the Aero nullification), but then back to the desktop.
post #8 of 11
That is strange, especially if it works fine straight from the disc, and if the backups play fine with the standalone.
You might be best opening a support ticket with Arcsoft or posting on their support forum, unless someone else here may have experienced the same issue.
post #9 of 11
Opened a support ticket @ Arcsoft. They emailed a logging program (ASLOG) which traps errors during TMT6. Tried the logging program, and when active, it solves the problem (BR backup discs and ISO's play from WMC TMT6 plugin). However, with the logging enabled, the output is unwatchable due to stuttering. So, I could not get a clean log of the error, because the logging program masks the original error, and can't be used as a fix, since it makes BR playback unwatchable. Forwarded the log to Arcsoft, and they are studying it now. MOre when I hear back from them.
post #10 of 11
I just purchased TMT6 for this same reason and I see the same problem when playing blu-ray folder through WMC8 through TMT6. TMT6 plays the blu-ray folder just fine outside of WMC8.
The exact issue I'm seeing when playing a blu-ray through WMC8 is that the screen goes black and only audio plays. Like I said, any updates or info would be appreciated. Thanks!
John
post #11 of 11
.....Forwarded the log to Arcsoft, and they are studying it now. MOre when I hear back from them.
jsauser11, did you hear back from Arcsoft yet or were you able to resolve your issue otherwise?
It sounds like your and my issue is almost if not the same. I started a thread over at the Arcsoft forum, as well as opened a ticket with them. Thus far I am not yet at the 'logging program stage' of their troubleshooting efforts.
_____
Axel
