AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Any Advantage in Running HDMI Straight to Display Instead of through a Receiver?
post #1 of 5
If I run the video signal from my blu ray player to a receiver and then to my display, aren't I running some risk of degrading or changing the signal in some way? Seems like the purest method would be to run it straight to the display, no?
post #2 of 5
The audio makes no difference to you? Or do you have dual hdmi outputs on your player? Personally I just use pass-through on my avr as far as video processing is concerned as my tv does a great job.
post #3 of 5
I would run separate HDMI audio and video cables to preserve HD audio.
Passthrough means the signal is untouched?
post #4 of 5
post #5 of 5
Discussed many times over.
S~
This thread is locked
